Hi there,
I am currently developing a kiosk type PC which should only be switched on several hours a day. I know how to automatically switch off the PC using the "shutdown -s -f" command scheduled with the Task Scheduler in Windows XP.
However, I do not know how to automatically startup the computer at a specified time (either using hardware or software). We use a time clock on the power supply of the other components (screen etc.) to switch the power on and off at the required hours, but can this also be used to power on (and boot) the PC?
Does anybody know a viable solution to this problem?
Any help is greatly appreciated! Thanks in advance,
bder
bder
