Archived from groups: alt.games.coh (
More info?)
Shenanigunner <nsp@nitrosyncretic.kom> looked up from reading the
entrails of the porn spammer to utter "The Augury is good, the signs
say:
>Robotech_Master <robotech@eyrie.org> wrote:
>>> Maybe that's the tip-over to use my free respec (I don't have much
>>> to fix or change, except one bad slot) - reclaim what value I can
>>> from my 30 Accs and reslot for Damage.
>> If you're going to be respecking anyway, that would probably be a good
>> idea. 2 Accs at *most* will cap you against almost anything you'll be
>> taking on. As you are now, I expect you could probably *hit*
>> something 9 or 10 levels higher than you--but you'd do them so little
>> damage that there's not much point.
>Huh. I still can't figure out where I got the idea that all/most Acc was
>a good idea - is that more for Blasters or Scrappers? Slotting up damage
>will really help my tank.
It's a good thing to do when you're low level, since training accuracy
boosts help quite a bit, even at only 8% each, but adding 8% damage to
an attack that only does 10, is kind of pointless.
By the time you hit 22 and get SOs, the base damage has scaled up enough
that adding 33% boosts to it is worthwhile.
I've liked running 2acc SOs in attacks, just because it gives me a
little cushion, so if I have to fight someone a bit higher than
expected, or get acc debuffed (CoT), i'm not stuck missing all the time.
Missing really bugs me.
The one time it _might_ be sensible to slot 4 acc SOs, is in a special
status attack power that you REALLY need to hit every time.
I didn't take cobra strike on my scrapper and i've not taken stun on the
tanker - it's just never seemed like a necessary thing to do.
Someone who fights in a team a lot and isn't the only damage dealer
might find it hand to have an almost sure-hit stun attack though.
[Barring the annoyance that disoriented mobs STILL weeble-wobble off at
high speed when stunned. Faster than my sprint speed anyway.]
>I don't really need to respec - the only real error I have is dropping a
>slot on Sprint and not taking Health and Stamina sooner, but I may as
>well use the freebie to fix the order of choices, move that slot and
>reclaim some value from the unneeded Accs. I'm already at the point where
>Inf is piling up, so I should be able to reslot 30-31 SO across the
>board.
>I also completed the mission for Agent Six and !!!WOW!!! are her prices
>less than the contact Philippa - more in line with the other stores. Why
>in the HELL does a contact have such inflated prices - 75% or more higher
>than store prices? Yow!
They still aren't cheap though. I hit 32 tonight, though I haven't
actually picked a power yet I went shopping at Penny (mutation).
With a little over a million inf, I manage to slot up stamina with 35s,
and all my accuracy, resist and endurance reducers as well as the 6
rechargers in hasten.
Now, all my damage SOs are yellow, as are travel powers, health etc,
since I only have 10k left.
The boosted mobs from playing on max difficulty means I make more exp
and inf per mission, but I do less missions before I level so I end up
with less inf than I would have made otherwise.
Oh well, i'm still going through most enemies (except bosses) like a
chainsaw through butter, I can wait a bit to get my damage SOs upgraded/
Xocyll
I don't particularly want you to FOAD, myself. You'll be more of
a cautionary example if you'll FO And Get Chronically, Incurably,
Painfully, Progressively, Expensively, Debilitatingly Ill. So
FOAGCIPPEDI. -- Mike Andrews responding to an idiot in asr
