Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Graphics Card, Help!
Forum Graphic & Displays : Graphics Cards - Graphics Card, Help!
Thank you for reading this, and thank you for the help.
My brother has an older computer that has an on-board graphics card. He bought an NVidia 7300 yesterday in order to play a game that just came out.
After uninstalling the old drivers, he plugged the card in the slot, plugged the monitor into the card and got nothing but a black screen after turning on computer.
The power supply is adequate to drive the card, anyone have any things we can check to fix this? Thanks again.
Sponsored Links
Quote :
You could try going into the bios and setting the INIT VIDEO BOOT (Or something similar) set it from onboard to AGP or if thats a PCIE card you got.
Another thing is if that doesnt work is, leave the 7300 in there, plug your monitor into the onboard card, boot it up and see if windows detects your new card. Load the drivers then reboot and plug in the new card.
Good Luck :)
Reply to JJMAN
Make sure the card is seated correctly. What powersupply is he using? Also list the rest of the specs of his setup to further determine the problem he has right now. JJMAN's opinion is one of many.
Reply to enforcerfx
Quote :
Yep mine is only one source indeed. :) Making sure the card is inserted all the way is a big one I forgot to mention.
Quote :
I figured that if he typed that out that he already had an understanding that his Power supply was enough and that it was good. But it may be a flaky power supply. I've seen that so many times. :)
Reply to JJMAN
There are 1290 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
