I am using the CoolerMaster Centurion 532 case with the Gigabyte 965P DS3 mobo. There is an audio cable in the case that has a 10 pin connector (pin 8 is blocked) that says HD Audio, then on the same cable there is an identical connector that says AC97 and from that connector continue 9 individual wires that have 2 stickers around them - one says AC97 and the other Azalia.
The mobo has an F_AUDIO male connector on it. Which female connector from the case do I plug in it - the HD Audio, AC97 or the 9 individual wires?
For the PSU (Fortron 450), do I just use the connectors that I need based on the plug configuration for the optical devices and leave the rest just hanging (or tucked away)?
The case fans have 2 4-pin plugs - one male and one female. How do I connect those?
One more question - does it matter which side is up on the HDD? There is the smooth side and the side with the circuitry. Which goes up or does it matter?
Sorry for what may seem like stupid questions. The manuals that I have are very skimpy and don't exactly tell me much.
Thank you very much for your help, David
