Just finished building my new PC, but when I plugged it in and turned the switch on the power supply absolutely nothing happens. Pressing the power switch on the front of the case does nothing either.
I am using Gigabyte DS3 mobo with FSP 450w PSU. I plugged the 20-pin molex into pins 1-20 of the mobo and the 4-pin molex into another plug on the mobo (at the top). I wasn't sure if the 4-pin was oriented right.
Any thoughts on what to try next? Is the 4-pin supposed to be plugged in?
Thanks.
Thanks.
