I have wound up with over the years with a dual 120mm fan radiator, a single 120mm fan radiator, a Swiftech CPU water block w/220W TEC, a Swiftech GPU water block w/80W TEC, a regular north bridge water block, and a pump.
How I have it setup right now is:
Pump > Big Rad > CPU > Small Rad > GPU > Pump
(I’m not using the north bridge block right now)
My question is if you should use a Y connector and run 2 loops? One for the CPU and one for the GPU. Like this:
Pump > Y connector > Big Rad/Small Rad > CPU/GPU > Y connector > Pump
