Tom's Hardware > Forum > Wireless Networking > Range & connectivity > Need to setup a wireless lan between 2 building 150m away .
Forum Wireless Networking : Range & connectivity - Need to setup a wireless lan between 2 building 150m away .
Any1 can tell whay would be the best router or antenna if there are only 1 tree blocking the view of these 2 buildings ?
Sponsored Links
Ok, let's look at a simple setup to get you started:
Building 1-> Router-> AP w/ HighGain External Antenna->
--- ->Tree-> --- ->
AP w/ HighGain External Antenna-> Router-> Building 2...
First, note the High Gain External Antenna. You will be needing 1 of them for each AP. :? Second, both of the AP's have to be in Bridge Mode. So be sure to find an AP that supports Bridge Mode. :o
I'm not the man with the most knowledge about Wireless in this Forum, but i hope that this might help you on the right way. :wink:
Reply to The-Pizzaboy
- 0 +
Quote :
You need a wireless bridge (not AP or router) on each end. Some routers / APs can be configured to operate as bridges (but not all). Beyond the infrastructure device, you then have the distance problem. What is your budget?
Reply to Iceblue
I've had good luck using Linksys wap54gpe, but they've never stayed up for long term use. You can always additionally order external antennae, but I've never needed them with these radios in a similar situation to which you describe. I think they run around 400-450 each.
While we chose those radios because PoE was a requirement for us (it was a very interesting project), there may be cheaper solutions out there as well. I know there are also a lot more expensive ones. We also have a permanent wireless bridge set up using dual band 2.4/5.4 SMCs which works very well.
Reply to lotussama
There are 455 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
