Just finished a motherboard swap for my old PC.
I am 90% positive I have everything plugged in correctly however, I push the power button and everthing starts to power up (CPU fan, HDD, etc.) but then it almost immediately stops and dies. Definitely 'feels' like the Power Supply is shutting itself off, I just cant find the reason
I was only unsure about the really annoying Power/Reset/LED cables, so i took them all out except for the power one (which only works one way, i tried it several different ways) but same problem.
Also, I have to switch off and switch on the PSU after each attempt, dont know if thats a significant symptom.
I am not sure if I have enough power, however, all i did was switch mobos, so I assumed it would still be ok.
Thanks in advance for any tips!
