Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Problem with X1900GT
Forum Graphic & Displays : Graphics Cards - Problem with X1900GT
Hi guys, I have a problem with my X1900GT
Here's my system setup -
Powercolor X1900GT on Catalyst 7.1 Drivers
Topower 500W PSU
AM2 3500+ CPU
MSI K9NGM-L Mobo
1 Gb 667MHz Patriot RAM
Win XP OS
I haven't overclocked the card; it is running at stock speeds.
When I play Dark Messiah of Might and Magic(patched to latest version), the screen sometimes freezes in the midst of playing and blacks out for about 3-4 minutes. I can hear the fan on the card get instantly louder while this happens. After a few seconds it quietens down, and 3-4 minutes later the game resumes at where it was before the screen froze.
This happens every 10-15 minutes of playing so it is quite irritating. I tried lowering the settings(HDR, AA, AF, no shadows, etc) but the problem persists. What might be the problem?
Sponsored Links
I think it might be your card over heating, or maybe not enough power from your power supply.
Reply to kaen
- 0 +
Quote :
I haven't overclocked the card at all, I imagine the stock cooler is adept enough to handle it. X1900GT was supposed to be betn 70-80C when running 3D apps anyway.
I calculated with various online power calculators before buying my current PSU, and it never got close to 500W. I don't overclock my CPU or RAM, and everything runs at stock voltage. The efficiency of my PSU is at least 70%. And yes, the 12V rail supplies more than enough, according to Powercolor specifications.
Anybody experienced a similar problem before?
Reply to STUBBY
sounds like heat to me. or GPU recover kicking in for no paticular reason?
use something like ATI tool and run something intensive, keep close eye on your temps.
Reply to raven_87
- 0 +
Quote :
Brought the card to vendor for testing, he says there's something wrong with the RAM. Still under warranty so I RMA-ed.
Thanks for the help anyway.
Reply to STUBBY
Hell, if the temps arent that high and your getting artifacts, usually thats the first indication of your VRAM thats been rainbowed.
Reply to raven_87
Quote :
Those temps are fine, my runs at similar temps during games too.
I got that few times too, until I got rid of the Catalyst. Since you RMA'd, then hopefully your new card won't be causing issues.
Reply to prozac26
- 0 +
Quote :
You changed to Tray Tools? How was Catalyst causing the problem? It kept reverting to stock speeds?
Reply to STUBBY
There are 471 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 13:08 OvrClkr won the Overclocking badge
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
