hi, im planning to change my vga stock cooler because i want lower temps, i have a 7900gt and the temp idle is around 60C.
My point is that i live in Panama and the normal temp in this country is arround 30-35c so you know this country is hot.
I dont know if the watercooling will do the best performance vs a fan cooler.
the water cooling kit for vga that im planning to buy is the thermaltake cl-w0052
http://www.newegg.com/Product/Product.asp?Item=N82E16835116017
And the fan cooler is the zalman vf-900
http://www.newegg.com/Product/Product.asp?Item=N82E16835118001
Need advice because i know that i cant lower the temp because of my exterior temp is 2 hot but i need at least to have the same exterior temp on my vga card.
I dont plan to get the hole watercooling sistem because i have a good cpu cooler and my temp is from 38 idle to 47 in full load and i have a am2 38000+
