Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Concerned about Power Supply and new system.
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Concerned about Power Supply and new system.
Hi All,
I am looking at an nSpire x-treme 600w powersupply to power the following:
Intel E6600
P5N-SLI
2 Gigs Crucial RAM (667Mhz).
Nvidia 8800 GTS.
2 x Seagate 250Gig HD SATA2
4 120mm fans.
Does anyone have experience with nSpire? Would the PSU be sufficient to add a second 8800 GTS when the prices hit bargin basement level and perhaps another hard drive?
Quote :
Nspire 600 WATT -- ATX2.2 Power Supply
This power supply has the switch on the rear
600W ATX P/S
Retail box
Fan: 140mm
Material: Steel
Warranty: 2 year
Dimension 150mmX160mmX86mm
20/24pin connection: 1 500mm
4+4pin 12V connection: 1
6 pin PCI Express COnnection: 2
5 pin SATA connection: 4
4 pin peripheral power connection: 6
4 pin floppy power connection: 2
Voltage Output : +5V = 28A , +12V1 = 18A, +12V2 = 18A, 3.3W = 30A, 5Vsb = 3A
Input: Universal 100~240VAC, 50/60Hz
Weight: 5lb (gross)
Thanks.[/quote]
Sponsored Links
There are 1055 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
