Tom's Hardware > Forum > CPU & Components > CPUs > Regarding system stability (Vcore and temperature)
Forum CPU & Components : CPUs - Regarding system stability (Vcore and temperature)
I have read some other posts here with regards to vcore varying underload.
But my CPU fluctuates from 1.14V - 1.28 (though 1.28V only lasts for less then 10 seconds). But this happens occasionallly. Normally values are around 1.14V
What about the other voltage readings and temperature values? Are they reasonable for a non overclocked machine
3V rail = 3.33V
5V rail = 5.09V
12V rail = 12.14
CPU temp = 40 Degrees C
MB = 26 Degrees C
Here are my comp specs:
E6600 2.4GHZ
Enerma PSU 535W 34A total on 12V rail
ASUS P5B deluxe motherboard
ASUS EAX1900XT (ATI) graphics card
Antec Nine Hundred Case
Programs used to look at vcore change
ASUS probe 2 v1.04.05 (look at rail voltage readings and temp_
CPU-Z
Sponsored Links
There are 1221 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
