Archived from groups: microsoft.public.win2000.security (
More info?)
I have only tried it with a Enterprise CA and the certificate shows the new effective
date right away in that case so I can't be much more help other than saying make sure
you copied the private key also which would probably require the use of a .pfx file
that password protects the private key. If you have Web Enrollment available on your
CA you might try to request a new certificate that way. --- Steve
"And" <andcripps@yahoo.co.uk> wrote in message
news:c59162da.0406290116.3cfd25b@posting.google.com...
> Hi Steve
> We don't have an online cert authority, only a stand alone one. So
> basically I've raised this request, copied it on to a floppy, ran it
> through the cert authority and placed the new cert in the same area as
> the old one through the server wizard in iis.
> One thing I did notice was that the old certificate was not over
> written, it was still available, I took a backup of it and deleted it
> so it should no longer be interferring with it, but it still shows
> externally that the certs out of date.
> cheers
> "Steven L Umbach" <n9rou@nospam-comcast.net> wrote in message
news:<Ad2Ec.130552$0y.12695@attbi_s03>...
> > Did you select the second option to send it immediately to the online CA assuming
you
> > have one that can receive the request?? If you did, it should have been renewed
right
> > away and you should have seen today's date as the new effective start date when
you
> > view it. If that did not happen check Event Viewer on your IIS server to see what
it
> > reports. --- Steve
> > news:c59162da.0406280623.4869ea5b@posting.google.com...
> > > Hi
> > > I've got an ssl certificate which is used for people to get access to
> > > a secure area. I've renewed this today through a renewal wizard in
> > > IIS, and it all seems ok, only when trying to access this over the
> > > internet it shows that is still has the old, out of date certificate
> > > on there. Does anybody know of other areas which may need updating?
