Tom's Hardware > Forum > CPU & Components > CPUs > HELP WITH NEW BUILD!!!
Forum CPU & Components : CPUs - HELP WITH NEW BUILD!!!
installed xp....turned the computer off....and the computer keep rebooting...
it never posted...
tried resetting cmos....
power supply paper clip test(worked..power supply worked...no stress)
Mobo worked fine on my other computer....
WHAT COULD IT BE?!?!
Sponsored Links
Most probably you have put the 'power' connector of the ATX switch on the 'reset' pin, just have a look at it.
Reply to m25
There are 1068 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
