Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Dell XPS Gen 4 (what is my power supplys amps) please help
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Dell XPS Gen 4 (what is my power supplys amps) please help
I have a xps gen 4 and I want to upgrade my graphics card (currently its an ati radeon x850) but i dont know what the power supply amps are. I know that its got a 450watts (it was the default power supply that came with the system) but nothing else can someone please help me. I need to know what the volts are, I presume 12v and the amps? Because its a xps gen 4 it means that I cant open the case and read it off the power supply unit because its got a green cover on it that wont come off.
I want to get a "BFG 8800 GTS" this is its internet link
http://www.bfgtech.com/8800GTS_640_PCIe.html
please help me
Thanks in advance
Sponsored Links
he can't replace the psu, because it is custom to the case.
I have a gen 5 with a very similar psu. I think that it should handle the GTS, but i don't know for sure. I put a GTX in mine, but since I couldn't change the psu i got this: add on psu
it works great! no problems what so ever.
Reply to Jazzman1284
You can't be sure that just any psu will work with a Dell. The pinout may be different. I've seen a few that were destroyed by new power supplies. I have no idea when or why Dell does this, but they do. Better ere on the side of caution, and buy one specifically for Dell. Besides, unless you have a bunch of hardware, the psu you have now will work fine.
Reply to baddog1
This is off the requirements page of the card
"A 400W PCI Express-compliant system power supply with a combined 12V current rating of 26A or more"
Should my 450w power supply be ok? its the "12V current rating of 26A or more" that has confused me because I don't know much about power supply units.
Thanks for your replies
:wink:
Reply to zebie
you guys are fab thanks for the help :D
Reply to zebie
There are 1177 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
