GPU-dedicated power supplies
  • Graphics Cards
  • Peripherals
  • GPUs
  • Power Supplies
  • Graphics
  • Product
February 8, 2007 11:06:15 PM
In terms of wattage, which pci port mounted, peripheral GPU-dedicated power supply would be required to run the high end nvidia or ATI video cards?
More about : gpu dedicated power supplies
February 8, 2007 11:47:37 PM
Say a X1950XT. About 450 watts - preferably more. Dedicated, 300w imo as these are cheap.
Though, your going to need sufficient amperage on the +12 volt rail. This is just as important. 25 amps and again - preferably more. Dedicated may be around 20a to be safe.
February 9, 2007 12:34:43 AM
Have any notion as to where I might walk in and buy one?
February 9, 2007 1:01:51 AM
look at power supply suppliers, not just the pc atx ones, whichever one you find be sure to tie the dc grounds together to avoid any potential ground loops that could fry the card
