Hi
I'm in the process of upgrading my AMD system to Intel. I roughly know what spec I'm after but wondered which parts to upgrade first...let me explain...
My old system is an AMD Sempron 2800, 512mb pc3200 (400) memory, GT6600 128mb AGP graphics and 2 x 80gb IDE HDs. I've made up my mind to switch to Intel Core 2 Due - and as I'm on a budget I expect the E6300 so....
I can't afford to buy all the bits in one go and so bought an ASROCK DUAL VSTA motherboard and a second hand Pentium D 820. I've plonked all my old bits that fir into the MB and now have an intel system on which to build on - stage 1 complete
Now , I intend to spend about £50-£100 per month and get the rest of the bits over the next few months - my question is in what order should I replace the bits and see noticable improvements?
The bits to get - 1gb DDR2 memory, 250gb SATA HD, E6300 CPU, PCI-e graphics card. Eventually I will change out the MB but that can wait a while.
I was thinking of this order:
1 - Memory (room to breathe)
2 - HD - (nice and clean re-installation of XP)
3 - CPU - (just about have enough saved by then)
4 - Graphics card
I left the CPU towards the end as I thought my existing kit would just hold it back - I want to see it fly when I put it in!!!
On another issue......
My now Intel set up appears no faster than the Sempron 2800. Is that expected bearing in mind the components I've retained? Not done any benchmarks - just my jusgement on start up times etc
Thank you all!!!
wicket
4 - Graphics card
Thank you all!!!
wicket
