Scrivner quests: Henchman problem
Archived from groups: alt.games.neverwinter-nights (More info?)
I can only have 3 henchman at most.
Right now, I have my golem, Narath-whatever (the drow), and Valeth.
How can I unsummon the golem? I made it with good regeneration, so I
can't kill it fast enough. There is no unsummon option for it. When I
drop the control amulet, the golem doesn't go away. I also cannot talk
to it and ask it to part ways.
Why not ask Narath or Valeth or part ways? They will not come back to
me when I have two henchman (golem + whoever).
I looked in nwnplayer.ini to see if there was a max # of henchmen
setting---no dice.
Any ideas?
Thanks,
Curtis
3 answers Last reply
More about scrivner quests henchman problem
  1. Archived from groups: alt.games.neverwinter-nights (More info?)
    > [snip]
    I've never had the golem as a henchman myself, but you could try
    right-clicking it and navigating to the "remove from party" icon in the
    radial menus.
    HTH,
    Richard.
  2. Archived from groups: alt.games.neverwinter-nights (More info?)
    Thank you. Doing that trick on the golem was the correct thing.
    On 2005-06-02 18:12:08 -0600, Richard Buckle
    >> How can I unsummon the golem? [snip]
    > radial menus.
    > HTH,
    > Richard.
  3. Archived from groups: alt.games.neverwinter-nights (More info?)
    > > radial menus.
    My pleasure. For completeness I should mention that if a henchman has
    dialog options to ask them to leave, it's generally better to do that
    rather than use the radial menu, otherwise sometimes the scripts get
    confused and you won't be able to ask the henchman to rejoin later.
    Richard.
Games Video Games
