Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Need help, screen is blank using dvi
Forum Graphic & Displays : Graphics Cards - Need help, screen is blank using dvi
Hello felllas,
I m having trouble here. Recently I built a new system and planning to use it as a gaming PC. Below is the specification of the system:
Core 2 Duo 2.13ghz
Biostar 945P a7a
1Ghz DDR2 533
XFX Geforce 7600GT
250gb HDD
I assembled the system with no problem prior to experience in assembling alot of systems before. The problem is the graphic card has two DVI output (which means no VGA one) and I m using Viewsonic Optiquest. When I booted the system, the monitor failed to detect the signal eventhough I attached the DVI analog adapter. So, I cannot install the OS because I cannot see a thing from the screen.
How should i deal with this? Since this new system is using PCI-e I cannot test it out with my former AGP graphic card. I hope someone can help me to figure this out.
And let say if I get a vga graphic card temporarily for installing the OS, will the XFX one is guaranteed working? thanks alot for da help.
P/S: The mobo doesnt have onboard graphic device. :(
Sponsored Links
Some monitors aren't capable of displaying the signal from that card, even if you use an adapter. How old is your monitor, and what type? Try borrowing a late-model LCD from a friend, and try that on your sys.
Reply to madmurph
I just tried the pc using my friend latest wide screen monitor ( that monitor has its own dvi socket and my friend is using dvi cable ). But no luck. The graphic card's fan works fine which shows there is power but there is definitely no signal to the screen. I m using Viewsonic Optiquest lcd.
I ve been thinking what is the real problem behind this. Is the card DOA?
Reply to ryuhaikaru
The other thing that effects your video display is memory. Are you certain of compatiblity of your RAM with that motherboard? Try pulling it and re-seating it. Try the stick(s) in a different slot, making sure it's seated. Do you get any beeps or other indicators that the mb is going through post, even though you don't have a display? Can you borrow a couple of sticks from your buddy with the LCD, and try those on your board? If that doesn't work, it's starting to look like a dead card. Bummer.
Reply to madmurph
Thanks for ur reply.
Yes i m sure of it. I have DDR2 and that mobo has DD2 slot too. It fits well. Dunno, maybe I ll try tomorrow on my friends pc.
Reply to ryuhaikaru
There are 1140 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 16:28 bilbat won the Motherboards badge
  • 01:00 jayhsyn won the Freshman badge
  • 01:00 nesta13 won the Freshman badge
  • 01:00 petar won the Freshman badge
  • 01:00 sinsear won the Freshman badge
  • 01:00 UnawareAtol won the Uniformed badge
  • 01:00 buryaku won the Uniformed badge
  • 01:00 Redras0324 won the Uniformed badge
  • 01:00 dvdmania won the Uniformed badge
  • 01:00 ugotomega won the Uniformed badge
