Hi there,
I've got a strange hardware fault. Here's the story.
Recently my pc has been doing the following:
When I actively work on it (anything from word to gaming) it works fine. As soon as I leave it on to download and go to work when I come back the pc is screwed. This is what happens:
First you hear a cracking sound in the speakers, then the desktop turns totally black (ie like monitor is switched off except that it isnt off) and then back to normal desktop and then black again, this goes back and forth for about 20 sec during which time the mouse is only partially responsive. THERE IS NO BLUESCREEN. If i manage to shut down windows upon reboot my primary drive will be corrupted or an hdd that was reading or writing at the time of the crash will be partially corrupted. Sometimes I cannot shut it down and it just freezes or i press reset, result is the same everytime.
Recently this problem has gotten worse so now even when i'm actively using my pc it sometimes does it.
This is what I've done so far:
I have re-installed windows xp on my 74 gig RAPTOR, SATA drive, same problem occured! The drive gets totally corrupted when it crashes
So i installed win xp on my second drive, a 120 gig maxtor IDE drive. Same result there but the IDE drive DOES NOT get corrupted when it crashes. BUT IT STILL CRASHES.
This is why i think its a harware fault: Power supply? Ram? Graphics card (whilst playing games no graphics corruption was seen at all)?
My specs:
Gigabyte K8NXP-SLI
Athlon 64 X2 4800+ (new, 1 week old)
2x 512 mb Corsair XMS CL2 DDR400 dual channel ram
74 gig Raptor SATA
36 gig Raptor SATA
120 gig Maxtor IDE
250 gig Maxtor IDE
250 gig WD Caviar Raid edition
MSI geforce 7800GTX
NEC DVD burner
Thanks for the help!
My specs:
Gigabyte K8NXP-SLI
74 gig Raptor SATA
36 gig Raptor SATA
120 gig Maxtor IDE
250 gig Maxtor IDE
MSI geforce 7800GTX
NEC DVD burner
