I'm planning to replace the machine I built two and a half years ago. New machine will be mainly used for multi-tasking, audio editing and a spot of gaming. I seek stability, durability and semi-quietness (well, lack of noisiness). That last point may relate to the fact that I'm presently shooting for a boxed CPU - might it make more sense to get an OEM + custom fan or is the bundled one OK in this regard?
IDK if its in your budget but I recommend 2 gigs (2 X 1 gig) of ram, crucial is kool but ive heard super tallent and team xtreme make awsome modules. Personally the most recent PC i built for someone had 2 gigs of corsair DDR2 800 and I overclocked the proc (e6600) to 3.4 and it was screaming. Also with harddrive prices the way they are u can get a 320 gig HDD for less than 100 bucks just make sure u partition a small portion for windows and the rest for data just incase you have any system errors and have to reformat. Im not keen on the motherboard either but I dont have any personal experience with it so hopefully another person will post about it. Good luck
Get the Barracuda 7200.10, not the 7200.9.....10 is faster and really won't cost hardly any more
If you EVER plan on overclocking, then don't get a 945 motherboard, get a 965. But I doubt you'll be overclocking because your RAM won't take it. So in that case, that mobo is fine for your intended use.
DVD writer. Take a look at the Samsung SH-S182.....solid and cheap.
Floppy. Don't bother unless you have a very specific need or don't mind spending $4 LOL
Case. Get one with 120mm intake front fan if possible, and definitely a 120mm exhaust rear fan. Alot of people here swear by the Coolermaster Centurion for a budget case that's roomy and has good airflow.
& CrossFire. Unless you plan on running 2 identical Ati cards, don't bother with CF/SLI. Any P965 mobo with 1 PCI-E would be a better choice, especially if you o/c. Like these:
I can confirm that I will not be overclocking, and also that I have absolutely no intention of ever making use of CF/SLI. Might this mobo be a better bet taking into account my purposes?
a change of 0.01 rounds per minute wont make a big difference.
anyways the stock cooler on the core2duo is noisy when it goes above 70% depends on how hot your system gets, but for my part the stock cooler was to noisy for me.
What confuses me is that Intel charge you more for the E6400 yet as far as I can tell it's the exact same thing as the E6300 except with a higher clock speed! I've heard there's some good OC'ing potential to be had.
Of course, I'd have to go with the more expensive mobo if this was gonna be my plan...
The only thing I see are the stock speeds. If you o/c the change you make should be relative to the stock speed. I think most people are saying instead of a e660 or e4300, they say get a e6400 when getting either one would work.
On the drive difference, I have read that Seagate upgraded some of the electronics to solve problems on the .09 series.
my .03 cents
The 6400 has a higher multiplier, that's why it has a higher clock speed than the 6300. So overclocking a 6400 is "easier" than a 6300 to achieve the same speed, and it puts less strain on your motherboard and RAM. However, if you have quality parts, the 6300 will still overclock like crazy.
The stock cooler on the C2D is fine, nothing wrong with it. It does the job and does it quite well actually. However, if you want a VERY quiet heatsink and/or one that keeps your temps lower, then get an aftermarket one. If you don't have the budget now, then go with a stock one for now and get another one later.
The Zalman 7700 is good. Not the best, but is better than stock. There are better options, but they also cost a bit more too. So it depends what you plan on doing and what you want to accomplish. If you plan on doing some good overclocking, then skip the 7700 since there are better options.
The 7700's style is such that it blows down on the motherboard, which helps keeps other mobo components cool. The tower style heatsinks don't do this, except for the Zalman 9500/9700, which do it indirectly, but better than the other towers.
So if you're looking for a "blow down" model, then the 7700 will work, and there is also a couple offered by Thermalright as well, check them out.
I've finalised pretty much everything in my mind with the exception of the cooler, and therefore the motherboard. There are a lot of people who have found their mobo to be incompatible with the 7700 Flower Cooler because it won't fit on, and I really don't want that. I do, however, want to use that cooler.
Zalman's website isn't a lot of help in this regard as the compatible mobo list was compiled in Feb 2005.
