Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Help me with my first ever build
Hi i own a dell laptop which after 3 years has finally died on me. So i've decided to build my first pc. I have pretty much decided on the following and was lookin for any advise on my selection. I dont really know what im doing but have been reading all the forums for the last few days. The budget for this is on the limit with these selections. Thanks
Case : NZXT LEXA Black Aluminium Chassi, Screwless design
http://www.komplett.co.uk/k/ki.asp [...] 38&CKS=PCW
Power : Corsair Powersupply 620W Black, ATX/EPS, 120mm Fan, 8xSATA, SLI, WxHxL 150x86x150
power
Motherboard : Gigabyte GA-965P-DS4, P965, Socket-775, Firewire, ATX, GbLAN, DDR2, 2xPCI-Ex16
Motherboard
Processor : Intel Core 2 Duo E6600 2.4GHz Socket LGA775, 4MB, BOXED w/fan
processor
Memory : 2 X Corsair Value S. PC5300 DDR2 2048MB Kit w/two matched Value Select 1024MB (= 4Gb)
Memory
Graphics Card : XFX GeForce 8800GTS 640MB GDDR3, PCI-Express, 2xDVI/HDTV/HDCP, 320-bit
Graphics card
Hard Drive: Samsung SpinPoint T166 500GB SATA2 16MB 7200RPM
HardDRive
Optical Drive: NEC DVD±recorder AD-5170 IDE Black OEM DVD+R/+RW/DVD-R/-RW (Dual layer)
optical
Monitor: Acer 22" LCD AL2216Wsd, Widescreen, Silver/Black, 1680x1050, 700:1, 5ms
Monitor
Networking : D-Link DGE-528T PCI Gigabit Ethernet Adapter
networking
Wireless : Linksys Wireless-G PCI 54 Mbps 802.11g SpeedBooster, WPA/AES
wireless
TV card : Hauppauge! WinTV-HVR1300, Hybrid Card, PCI, Analog Tv-Tuner & DVB-T(Digital-TV)
TV card
Im going to run vista on that. Will everything work ok there and be compatible. As i said i dont really know what im at. Thanks. Also does anyone think it would be worth changing to an AMD of similar price ?
Sponsored Links
Looks like a solid setup and should see you through a good few years, can only nit pick on some issues such as having 1 large HDD rather then 1 smallish (75-150GB) fast drive and maybe 1 large one to store large files would improve the speed of the rig quite alot if its to be used for gaming.
You could properly save some cash if you went for the E4300 and a new heat sink as well. But that is reliant on you being able to over clock, but aside from those two looks good.
Compatibility issues with vista I not to sure on but I am sure someone else will be able to help you out
Reply to Chrisb6122
If i did that with the harddrives how would they be connected. would they just come up on "my computer" as 2 differant drives and would i save stuff to the big one like i currently do with my external for my laptop. Would the transfer speen between them be slow ? Also im getting that processor cos i dont know how to overclock but i am going to learn in the not so distant future. Is it difficult for newb
Reply to kingknacker
Quote :
Ok well as for the two HDD setup the faster drive would 'house' the O,S and other programs that are used very regular in Windows they would be displayed as two different HDDs as you have seen with your external drive and laptop HDD. As for the hardware behind it its just connecting one more SATA cable to the motherboard. The transfer between them would be slower then if they was just one drive but it is not that noticeable.
As for the CPU go with the E6600 if your not to sure. As i say solid setup and should serve you well, if you run into any problems let us know and we can try to help
Reply to Chrisb6122
well, I would go with a diferent case, such as the antec 900 if you can find it (which used to be $50 less on newegg, don't be deterred by the US pricing)
http://www.newegg.com/Product/Prod [...] 6811129021
And I would like toknow what you want the e6600 for, because if all you want is the clock speed, or think the cache is worth the difference, unless you can call 5% a big difference (usually only 1-2%, max about 5% differnce between 2mb and 4mb), then you should simply get the e4300 and save yourself some money and get the 8800gtx or wait until the r600 comes out. You're better off with a 4300/88800gtx or r600, than a 6600/8800gts, because the 4300 can be overclocked to be faster than the x6800 with some nice cooling, where as on the dx10 cards, it's the amount of unified pixel shaders that matters, so you're better off with the 8800gtx getting the cheaps stock evga one and overclocking it yourself
And I don't really think you currently need 4gb of ram, but since you have found some very cheap ones, that means it isn't a bad idea to get it, only problem is that it's very hard to overclock 4 sticks over 1 or 2
Rest looks good for now
Reply to I_Love_Tacos
There are 1352 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
