Tom's Hardware > Forum > CPU & Components > CPUs > Reset CMOS now stuck..help
Forum CPU & Components : CPUs - Reset CMOS now stuck..help
Hi
My system crashed and kept turning on then off so i reset the cmos.
I have a gigabyte dq6 board, and the computer restarts now, but i'm stuck on the black award modular BIOS screen, and can't seem to move from there.
A dual bios sign has come up, and it says that F1 to continue or Del to enter bios setup but when i press them nothing happens. Can someone help?
Screen also says that defaults have been loaded. :(
Do i need to do something?
Any help would be appreciated..
Sponsored Links
With the computer shut down, place CMOS jumper to normal. Turn on your computer. If original problem that caused you to switch your CMOS jumper persists, turn off computer, place CMOS to clear. System should automatically go into BIOS. Fix whatever problem that originally caused you to switch your CMOS jumper (memory timings, CPU overclock, whatever it may be), Save & Exit from BIOS, then shut down your computer. With the computer turned off, switch your CMOS jumper to the non-clear position. Start your computer. If problems still persist, take computer into a proffessional.
Hope that helps.
Reply to darious00777
Thanks for your help, i have fixed the problem. Stupid me didn't realise that my wireless keyboard was not connected to the tower therrfore not alowing me to press the DEL button. I have connected it now and the computer works fine.
I had the e6600 running at 3.33ghz but it would keep crashing, i had vcore at 1.4, and my 800mhz memory set to 1:1, i guessi need more voltage.
cheers :D
Reply to kasparov
Quote :
cheers :D
Glad to hear you got it fixed. Not having the keyboard plugged in will definately not help.
There are 699 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
