I am shopping for a new system and operating on about a $600 budget (new baby is expensive).
I have built a couple systems and also purchased a system from Dell with good results on both. Dell has a special right now of the following for $399 w/ free shipping:
Dimension E521 AMD Athlon™ 64 X2 Dual-Core 3800
Genuine Windows Vista™ Home Basic
1GB Dual Channel DDR2 SDRAM at 533MHz- 2DIMMs
HARD DRIVE 160GB Serial ATA Hard Drive (7200RPM) w/DataBurst Cache
OPTICAL DRIVE 16X DVD ROM Drive
VIDEO CARD NVIDIA GeForce 6150 LE Integrated Graphics GPU
SOUND Integrated 7.1 Channel Audio
I was wondering what you guys thought of that along with dropping these items in it to beef it up:
RAM Video Card
That's $570 for the system (+/- a few bucks). It would be replacing:
P4 3.2ghz (northwood)
1mb ram
9800 Pro
Viewsonic VX922 (this will carry to new system)
So what do you think?
Worth the money?
Wait until I can afford a Core C2D? (probably months away)
Any changes to the above to make it better? (without adding a lot of cost)
I will be using the system for gaming (EQ2, Oblivion, etc), office, web-browsing, email and other basic uses.
I have a Dell Dim. 4700 and I have been playing the "runaround game" trying to figure out what is proprietary and what is not. If you want a PC that doesn't cost a ton but wont be obsolete in a year or two, then buy yourself a nice mobo that supports Duo Core and build from the ground up yourself.
I would wait for Duo Core prices to drop myself, since the old AMD systems require lots of power (which means lots of heat), and aren't as fast as some of the slowest Duo Cores.
On the "beef up memory" part, you'll want to buy all of your memory at once in identical pairs, so that you can run dual channel. At the same time, a slower RAM module will force your PC to underclock the other modules so that they all run at the same speed.
YOU DO NOT WANT TO BUY VISTA.
Unless you are a software engineer and you need Vista for work, you do not want to purchase it until SP2 (probably a year and a half). You'd have to be the world's biggest sucker to volunteer to beta test Vista for microsoft right now. Your games will run slower, that PC wont run the Aero interface, and your GPU wont natively run DX10, so you have no reason what so ever to buy Vista. What's so bad about XP anyways? Why do you need to upgrade if XP works just fine? :?
I've had Dells for a long time. They are difficult if not impossible to upgrade. My E510 won't take a GTX, 8800 or other long video card, more than 2 hard drives, etc. It has a BTX mobo, making a real upgrade all but impossible. My next system will be a build with a big solid case that will become an evolving platform. That way I will be able to take occasional leaps in performance such as processor / mobo and so on.
There are some good threads here about building budget systems. My advice is to wait until you can ramp up your budget a bit. By then prices will drop and you will get considerably more bang for your buck. I'd avoid VISTA like the plague - unproven, driver-deficient corporate bloatware with anti-user features focused almost entirely on security (MicroSoft's, not yours).
Paul, the only thing proprietary in your Dimension 4700 is the front panel connectors. Not too hard to change that is it?
To the OP: I'm not sure abut the extra ram. If you feel 2Gb is really necessary, go for it. The video card is a good idea. While I don't care for the BTX platform, that price is impossible to beat with a build-your-own. Have fun.
Excuse me while I call bullshit. I've talked to Dell techies and they themselves have told me that I would not be able to reuse a couple of Dell parts that I was planning on including in a new build.
Just off the top of my head I can tell you that the mobo/cases are built to be used only together. Say otherwise so I can start ignoring you and move on with my life.
You might want to look into my post history in this subject before making such outrageous remarks. The only BS I can see in this thread is the FUD you're spewing. I know what is and is not true on the Dell computers of which I write.
No, your Dell case and mobo are not unique. Both are 100% mATX standard. That mobo will fit in any aftermarket case, and likewise, any aftermarket mATX mobo will fit in your Dell case.
But hey, if the concept of rewiring a couple front panel connectors is too much for your little mind to fathom, then by all means go ahead and buy new components.
There's your case with an aftermarket mobo and PSU installed. Ya, that's REAL proprietary...
Not true. While you have to be careful about the physical dimensions of the various possible components as you would in ANY build, not just an upgrade of a Dell, there are really no proprietary restrictions on most, if not all, newer Dells.
I don't know what those Dell techies really said. All I know is my own experience with upgrading a Dell 4600.
To the OP: Some things to consider (from someone who has been there and done that...as opposed to those who haven't):
1) Your motherboard will probably be your biggest problem when upgrading. The Dell-supplied motherboards tend to have fewer PCI slots, for example, than others...perhaps because they are designed to fit into cases smaller than ATX-size. Keep in mind that Dell might still use slower motherboards with locked BIOSes. There goes the overclocking option.
2) You probably can use a third-party power supply such as Antec. Maybe some older Dells needed proprietary power supplies. My 4600 doesn't.
3) You can use whatever case that your motherboard will fit into.
4) Use whatever RAM you want. Just keep in mind that you will be wasting money on the fastest RAM if your Dell-supplied motherboard won't be able to take advantage of it. There is no use in upgrading to fast RAM (more than 533 Mhz) if the Dell motherboard can only handle 533 Mhz or slower.
5) No restrictions on hard disks, CD/DVD drives, etc. Just make sure that your motherboard has SATA connections before buying a SATA drive.
If your intention is to buy a cheap Dell and then upgrade the heck out of it in order to achieve a fast, powerful system, then I'd advise against it. If this is your intention, it would be better to build from scratch.
If your intention is to buy a cheap Dell and then upgrade a little here and there to get a decent, moderately fast system, then go ahead.
This would run about $600 with shipping and you could get Kingston RAM that would be less expensive as well as a less expensive case. Then when you can afford, get a video card.
I thank you all very much for your feedback and input.
Quote :
I do not particularly want Vista, but it is what comes with the system. Considering an OS (whether XP or Vista) is another ~$100 to the cost of a "from scratch" system it part of the reason this system is in my price range at the moment.
Quote :
Get this and a nice lcd monitor
$850 vs. $399.... notice the difference? Don't need a monitor.
Quote :
That's my experience as well on my previous Dell.
Quote :
No problem, no plans at all to overclock.
Quote :
Right. Good point and the exact reason why I picked some 533Mhz to purchase with timings the same as the stock memory.
Quote :
You got it. I am realistic enought to know that my $500-600 isn't going to build a blazing system. That said, it should be a significant upgrade to what I have now. It will meet my currents needs (not my desires). I will not have a lot of $$$ tied up into something when the time comes and I CAN afford to build the system I desire.
Quote :
If you could live with onboard video...
No, I really dont think I could stand onboard video for anywhere near the time it will take me to afford my next system; I game too much.
Thanks again to all the replies. I am going to sleep on it today and make my decision tonight. The Dell offer expires tomorrow.
I didnt have any issues with my previous Dell power supply when upgrading. Do you think the stock PS will support the 7600GT ???
