Latest Reviews & Articles
Life At 2 GT/s: 6 GB DDR3-2000 Memory Kits Compared
Memory vendors put a lot of effort into drumming up excitement over high-end memory kits, but many of those products turn out to be vaporware. We test six DDR3-2000 kits that enthusiasts can actually buy today, and push them as far as they'll go. Read more
DDR3 Memory Scaling On AMD's Phenom II X4
DDR3 memory is available in speeds ranging from DDR3-800 to DDR3-2133. Which is the best memory choice for AMD’s Phenom II X4? We tested as many speeds as possible using aggressive and conservative timings to find the sweet spot for your next build. Read more
Intel Core i7-975 Extreme And i7-950 Reviewed
Today Intel launches two high-end processors that take the place of its i7-965 and i7-940 CPUs. More speed? Same price points? We’ll take it! But are the new chips compelling enough to warrant spending more than you would on an i7-920? Read more
AMD Athlon II X2 / Phenom II X2 And Low-Power CPU Bonanza
Eager to let you know it’s been busy, AMD is launching four new processors today: the first Athlon II, a dual-core Phenom II, and two low-power 65W Phenom IIs. We bought ourselves a new Pentium E6300 and let loose with AMD’s latest. Read more
All the Reviews & Articles
Tom's Hardware > Forum > Home Theatre > HDTV > Sony SAT-HD300 video problem
Archived from groups: rec.video.satellite.dbs,rec.video,alt.tv.tech.hdtv (More info?)
I recently "upgraded" my Sony HD200 to an HD300 because I was getting
tired of the constant spontaneous guide resets. The HD300's picture
seems a little darker and noiser than that of the HD200 and there is
a strange video glitch:
After the unit has been tuned to a particular station for a while
(5-20 minutes) there is a very brief flash of color much like what
you see on an OTA analog broadcast when an interfering station syncs
up well enough for the set to lock onto the wrong color subcarrier
for a moment. Once this has happened there is a subtle change in the
picture. It's hard to describe, but if you bring up the guide and
examine the text of a program description it will look a bit distorted
with the bottoms of letters pushed to the left. This is particularly
visible with lower case m's and n's whose "legs" curve to the left.
A correct picture can be restored by switching to a different station,
even from within the guide (by moving the cursor left to the sation
number). There is again that brief flash of color and the guide text
goes back to undistorted for a while. Switching stations again while
the guide text is undistorted does *not* result in a flash. The effect
is the same for composite or Svideo outputs. I am using a Sony XBR100
set and viewing DirecTV stations.
The effect felt enough like an NTSC color encoder problem (something drifts
and is then reset?) that I decided to look at the Y component of the component
output (running 480i of course) as a mono signal. It does not display the
distortion and does not experience the "glitch" when switching stations
(after first confirming that the guide text is in the distorted state by
looking at the composite output). To pursue this further I fed the component
outputs through a transcoding TBC and viewed the composite output. Now I had
color and again there was no distortion and no glitch on switching stations.
(There was some general picture instability which makes me wonder about the
HD300's overall system timing--the TBC is usually pretty tolerant.) Of course
that didn't really prove anything since the TBC could have been covering up
the problem. So I switched to the TBC's composite input (and the HD300's
composite output) and again was able to see the glitch on switching stations
with the guide text in the distorted state. The glitch looked a bit different
(presumably the TBS's input reacts somewhat differently from the XBR100's) but
it was definitely there. Still not conclusive, but it certainly seems like an
encoder problem.
If anyone is still reading at this point and has an HD300 to play with I'd
really appreciate any data to help me decide whether there is something wrong
with my HD300 or there is a general design defect. I hate to start talking
with Sony's support people (who will no doubt ask me which channel I have
the RF out set to and suggest that I remove and re-insert my access card
many times) unless there is some chance that a replacement HD300 will help.
(In the past I would have assumed that a problem like this could not be basic
to the design, but after the SAT-AD2 frame mismatch bug I'm no longer so
sure. :() If it is a design problem I'll be better off trying to find a
"simple" external component to NTSC encoder.
Dan Lanciani
ddl@danlan.*com
Sponsored Links
ddl@danlan.*com (Dan Lanciani) wrote in message news:<1331069@news1.IPSWITCHS.CMM>...
> encoder problem.
> Dan Lanciani
> ddl@danlan.*com
Mine works fine. Return yours and get ir replaced.
Reply to Anonymous
In article <ecba8b59.0407120734.2337a1b9@posting.google.com>, hpp@linkline.com (harry parrell) writes:
Did you try going into the guide (after having been tuned to one station for
a while) changing the station, and looking for the glitch? I ask because the
distortion is kind of subtle (and may depend on the particular tv set), but
the flash (and subsequent lack of flash on additional channel changes) is fairly
distinctive.
Dan Lanciani
ddl@danlan.*com
Reply to Anonymous
Mine also works fine it that respect. Mine however has another
problem. Twice in the last couple of weeks it has had fits where a
remote button press takes MNAY seconds until the unit responds.
Eventually, it goes into channel scan and then everything clears up.
AFJ
>distinctive.
> Dan Lanciani
> ddl@danlan.*com
Reply to Anonymous
In article <6s56f0p0p68edtulelrt0f978srmu2ncur@4ax.com>,
airforcejayhawk@comcast.net says...
Mine does that, except that I circumvent the process by pressing the
reset button (next to the access card) when it seems slow. Problem
seems to be happening more lately.
Reply to Anonymous
In article <6s56f0p0p68edtulelrt0f978srmu2ncur@4ax.com>, airforcejayhawk@comcast.net (Air Force Jayhawk) writes:
So perhaps there is some value in asking Sony to do something. I assume they
will send me a scratched-up "refurbished" unit to replace my shiny new one,
but I guess it would be worth it if it actually fixed the glitch. Just to be
sure now, you are using composite or Svideo and can't see any glitch/blink/flash
when switching stations by moving left to the station number in the guide after
being tuned to the previous station for, say, 20 minutes?
I just noticed mine doing that. Also, while moving through the guide listing
the yellow highlight will vanish completely for a while when it gets behind,
and then reappear after a few seconds. It was increasing behavior like this
(followed by crashes and loss of custom stations) in the HD200 that provoked
me to "upgrade" to the HD300. The life of these receivers seems to be getting
shorter and shorter...
Dan Lanciani
ddl@dalan.*com
Reply to Anonymous
[following up to my own post]
In article <1331069@news1.IPSWITCHS.CMM>, ddl@danlan.*com (Dan Lanciani) writes:
I've found a possibly less subjective way to identify the "bad" vs "good"
states. With the monitor connected to the HD300's composite output, enter
the guide and press "info" to call up the detail page. If the system is
in the "bad" state (i.e., has been tuned to the same station for long enough)
there is some great dot crawl on the borders of the detail box. If you have
changed stations recently the border lines are rock solid.
Dan Lanciani
ddl@danlan.*com
Reply to Anonymous
I have the Hughes HTL-HD which is essentially the same receiver less
RF remote capability. After the recent software upgrade mine has been
very stable and does not have any problems of significance as far as I
can tell. The avsforum has many threads discussing this LG built
DirecTV HDTV Receiver. Go to the avsforum HDTV Hardware section and
read about the issues. The LG LST-3200A is also the same basic
receiver.
Chris
> encoder problem.
> Dan Lanciani
> ddl@danlan.*com
Reply to Anonymous
(following up to my own posting)
After going round with Sony for a bit (and performing the expected power
cycles, removals/insertions of access card, NVRAM reset, etc. to no avail)
they decided that something is probably wrong. Unfortunately, since the unit
is now (just) over 30 days from purchase the best they will do is a refurbished
replacement some unspecified time after I ship my unit to them. Disturbingly,
they kept asking why I hadn't purchased an extended warranty on such an
expensive product. :(
Now if we were talking about an an advanced replacement with a refurbished unit
I wouldn't mind since I could I could reject the refurbished unit if it turned
out to be worse than the one I have. Or if it were a new replacement I'd
figure there wasn't much to lose. But with this deal I think there is a good
chance that I'll end up with a unit that (a) was returned for some other
obscure problem that has not actually been fixed, (b) is dented/scratched, and
(c) still has the problem I'm observing (which I'm beginning to think is a
design defect visible only on select monitors). Should I take the gamble?
Dan Lanciani
ddl@danlan.*com
Reply to Anonymous
[again following up to my own article]
The story continues... Since Sony was backordered on the refurbs I decided to
buy a new unit in the meantime. I figured I could always use the original one
for a second receiver after Sony exchanged it. The new unit does not have the
problem, so I was starting to be optimistic about the replacement. Today I
received the refurb replacement for the original unit. The refurb _does_ have
the problem, though the timing is a bit different and artifacts on the detail
page exist (slightly) even in the "good" state. I notice that the replacement
has a manufacture date of 9/2003 just like my original unit. The good/new
unit has a 2004 date (I forget the month). So either there were production
issues around the 9/2003 time frame (and the refurb process ignores the problem)
or maybe there was a design change between the bad units and the good one. I'm
not sure what to do now...
Dan Lanciani
ddl@danlan.*com
Reply to Anonymous
There are 718 identified and unidentified users. To see the list of identified users, Click here.
You are about to answer a thread that has been inactive for more than 6 months. If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread. Add a reply Cancel
Sponsored links
