Archived from groups: microsoft.public.windowsxp.basics (More info?)
Since installing Zone Alarm I have been unable to contact my network PC
When I tried to add the network PC to the agreed list I was prevented
because it was not on the approved list.
I have had to uninstall Zone Alarm in order to use the network
How do I add my network PC to Zone Alarm?
Blair
Sponsored Links
Add the IP address of the computer in question via Zone Alarm>Firewall>Zones
Tab and hit the Add button down there on the lower right. That should do
it! Good luck!
"Blair" <pabm@brachd.fsnet.co.uk.invalid> wrote in message
news:Olp7FwbHFHA.3088@tk2msftngp13.phx.gbl...
> Blair
Reply to Anonymous
Hello, Blair!
I hate to assume anything, so I'll simply ask! (smile) Do you know how to
set 'Trusted' IPs?
First, you need to *know* the actual IP address for each of your computers.
You didn't say which version of Windows you have, but in Windows XP you go to
Start > Run > and type: cmd [enter]
That brings up the DOS window. There you need to type: ipconfig /all
Write down the actual IP address. Do that on *both* (all?) networked
computers.
Open the Zone Alarm Control Center. (You can do this by double-clicking the
Zone Alarm icon in your systray -- lower right-hand corner of your task bar.)
In Zone Alarm click on Firewall (left-hand side in yellow). Then click the
Zones tab.
This is where you ADD 'trusted' IP addresses. On Computer One, you'd need to
add the IP address for Computer Two (three, four, etc.). Then go to Computer
Two and add the IP address for Computer One (three, four, etc.).
Set them for 'Trusted.' When you've finished adding the IP address, then
click OK. Then click on the APPLY button.
By the way, you 'find' your IP address a little differently with other
versions of Windows, so don't let that freak you out! Just let me know which
version you have...
Anyway, that should solve your problem, but let me know if you're still
having problems.
==CharlieMC
Zone Alarm
> Blair
Reply to Anonymous
re the other 2 replies - if you do not know the IP address of the computer
because it changes due to you using DHCP then you can also set a range of
IP's in the trusted zone to cover all IP's that you network can assign to a
given computer.
> Blair
Reply to Anonymous
- 0 +
Hi Charlie,
Your reply with your instructions were great! All worked as you specified
and I have Zone Alarm and the network working OK
My only problem is that the indicator for being on line in the right hand
tray is missing so there is no means of knowing when I am off/on line and
no means of cancelling on line.
Any ideas?
Regards
Blair
"CharlieMC" <CharlieMC@discussions.microsoft.com> wrote in message
news:AE1C2C41-5940-47AA-AD71-853BF7585815@microsoft.com...
> Hello, Blair!
> set 'Trusted' IPs?
computers.
to
> computers.
the
bar.)
> Zones tab.
to
Computer
which
> version you have...
> having problems.
> ==CharlieMC
> Zone Alarm
> > Blair
Reply to Blair
Network connections properties has a check box to run the
icon in the tray..
news:%23hEwm7iHFHA.3076@tk2msftngp13.phx.gbl...
| Hi Charlie,
as you specified
the right hand
off/on line and
| Any ideas?
| Regards
| Blair
message
| > Hello, Blair!
Do you know how to
| > set 'Trusted' IPs?
of your
| computers.
Windows XP you go
| to
ipconfig /all
(all?) networked
| > computers.
double-clicking
| the
corner of your task
| bar.)
| > Zones tab.
| to
Then go to
| Computer
four, etc.).
IP address, then
Just let me know
| which
| > version you have...
if you're still
| > having problems.
| > ==CharlieMC
| > Zone Alarm
I was prevented
network
| > > Blair
Reply to Anonymous
- 0 +
Thanks for your help. I do have the check box already ticked but still no
icon
But it was the internet connection icon I was referring to.
They both disappeared after I had reinstalled Zone Alarm
Blair
"Jim Macklin" <p51mustang[threeX12]@xxxhotmail.calm> wrote in message
news:%23mNT4bkHFHA.3612@TK2MSFTNGP09.phx.gbl...
> icon in the tray..
> | Hi Charlie,
> as you specified
> the right hand
> off/on line and
> | Any ideas?
> | Regards
> | Blair
> message
> | > Hello, Blair!
> Do you know how to
> | > set 'Trusted' IPs?
> of your
> | computers.
> Windows XP you go
> | to
> ipconfig /all
> (all?) networked
> | > computers.
> double-clicking
> | the
> corner of your task
> | bar.)
> | > Zones tab.
> | to
> Then go to
> | Computer
> four, etc.).
> IP address, then
> Just let me know
> | which
> | > version you have...
> if you're still
> | > having problems.
> | > ==CharlieMC
> | > Zone Alarm
> I was prevented
> network
> | > > Blair
Reply to Blair
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Zone Alarm problem
There are 998 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
