Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > 8800 GTX water cooling
Forum Overclocking : Cooler and Heatsinks - 8800 GTX water cooling
I'm looking into watercooling right now for my enw rig and I was wondering if the Thermaltake BigWater kit would be compatible with an ASUS P5B Deluxe LGA 775 Motherboard and an PNY 8800 GTX video card. If its not can I just buy custom parts to fit?
Sponsored Links
DO NOT get a thermaltake big water...I have it and it was such a waste of money. You can get better performance out of a cream of the crop air cooler. The only guideline for water cooling is you actually have to invest a pretty penny into it...If you get one of the lowly kits or not put enough cash into it you won't get results that are worth making the leap.
If I could take back the 150-200 I put into this water cooling rig for air cooling...Or take that cash and add onto it to get a custom swiftech solution...I would do so....
STAY AWAY FROM THERMALTAKE!...can't stress that enough..
If you really want to get water cooling ask around for whats good and get some feedback depending on your needs...
Reply to Kamrooz
Actually, you either have to spend a lot of money on custom manufactured parts, or spend a lot of time converting parts from other specified uses and redirecting them to water cooling your PC. For instance, you can spend $60-$80 on a Black Ice Rad from Danger Den, or spend $5 at your local junk yard pulling a heater core from an old Oldsmobile or Chevette and then leak-testing it. In practical terms, the two work about the same for what they do. Just one requires you to get your hands really dirty.
As for myself, I tend to mix and match, finding tubing from a local hardware and plumbing supply store and buying key components online (such as pumps, radiators and cooling blocks). I've also been experimenting with a custom built reservoir I made from 1.5 inch clear PVC pipe...it's working pretty good, and only had to fix one leak where the PVC cement didn't form a seal.
Reply to Houndsteeth
- 0 +
Yea...This was my first water cooling rig. Only reason I got the thermaltake bigwater was because someone had the same exact setup as mine when it came to psu, mobo, cpu, and case. He also got some damn great results...But for me it turn out to be major crap...A lesson learned for me. A lot of people told me to go custom and buy parts here and there..Stupid of me not to listen...For my next rig though going to do exactly that..Going to post here When I'm purchasing and get info on the best setup. Everytime I build a pc I literally get cutting edge in all categories cept for HD's....But this time I think I'mma go for the cream of the crop in hard drives as well. But yea...Big mistake for me getting the big water...=(...
For my next rig going to get 2 seperate water cooling rigs maybe...one for the cpu and one for the gpu/chipset...^.^....going to overclock the shiat out of it...I got my current 3.2 prescott (I know..I need an upgrade bad) to 4 ghz on the bigwater...But with HIGH temperatures that weren't worth water cooling...Now my bigwater has deteriorated over time and just keeps getting worse and worse. Plus it has a leak somewhere so it evaporates constantly and I have to refill. my load temp is literally around 63-67 c....Idle is 55....and that's back down to STOCK Settings...I disabled my overclock cause this water cooling rig just blows chunks. I would spend some cash to just toss this out for a good air cooling solution since atm it can do better...But this thing is atleast lasting for a bit even though I have to replace the liquid...I'm just waiting till I buy a complete new rig...About time since this sucker is a year or two older then I'd normally use.
Reply to Kamrooz
- 0 +
Well since Dangerden already makes a water block for the GTX you might also want to check out thier DIY kits for cooling the rest of the system. Or build a custom water cooling rig using thier components.
8800GTX water block
-ouch1
Reply to ouch1
Quote :
Well since Dangerden already makes a water block for the GTX...
BFG sells an 8800GTX with the Danger Den waterblock preinstalled. (It has a BFG logo etched instead of a Danger Den logo.)
http://bfgtech.com/8800GTX_768_PCIe_wc.html
http://www.newegg.com/Product/Prod [...] 6814143079
PC Gamer magazine called it "stiffy-inducing" (Feb. '07). I wouldn't go that far, but it is pretty damn nice. I even took a picture of it to work....
It took me some self-debate to justify the cost, though. Ultimately I decided: A "normal" 8800GTX is $600. The waterblock is $150. For an extra $50 I know it's installed correctly, I get a lifetime warranty, and I get a single-slot card. And a BFG t-shirt, too, well now that just cinches the deal.
Reply to rsquared
Yeah, and the card cost $800-$900. I'd say the stock cooler for the card is decent, a lot better compare to 7series.
Reply to chuckshissle
- 0 +
Yeah, at least the heat is vented out the back now instead of into the case :roll:
Reply to Valtiel
mi 0.02 :
instead of the full DD block for the 8800 (too expensive) I've been thinking on saving a lot of money and trying to fit a maze4 plus ram heath sinks over ram and vreg.
Somewhere i see a guy doing it, it was way cheaper and worked good
but not sure all the work he had to do to fit the maze4
Also I heard swiftech has a plan to release a kit of gpu block + hs for 8800's...
anyway, the 8800 is still too new and don't want to damage it by mistake lol... also no OC is necessary yet so at least I will recommend wait a couple o months until the new blocks are for sale or OC becomes necessary
Reply to holy_cow
- 0 +
im not going to be OC'ing it yet but it will be compatible with the BigWater SE right?..i just got it for a 30 dollar deal at a local place, figured it was worth it. I 'm not OC'ing much though, just want to keep things cool. I have a Mozart TX case so it has pretty nice airflow and space for 10+ fans (5 alreadi installed)
Reply to chailvr
There are 1266 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
