E6300 Stock speed Gigabyte DS3 latest BIOS X1900xt 256 GSkill DDR2 800 4-4-4-12 (Blue spreader) @2.1v Aspire 500W PSU (Clear Blue Model) Thermaltake Big Typhoon W/ Silverstone FM121 fan @ 1000RPM's Voltage Idle From Easytune VcoreA 1.25 +3.3v 3.32 +12v 12.49 (kinda high?) CPU Vid 1.32 (??) Temps Idle Easy Tune System 39c CPU 23c TAT- 39c both cores Volts Load Using TAT recoded from Easy Tune VcoreA 1.33 +3.3V 3.32 +12V 12.36 CPU Vid 1.32 Temps Load using tat recorded from Easy Tune System 39c CPU 43c TAT full load 55c core0 51c core1 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Story: My PC suddenly died the other day. Took my two days to narrow it down. The CPU died and I replaced it with another E6300 Worked fine for 1 day and I overclocked it to 400x7 1.325v and Ram at Factory 800 4-4-4-12 2.1v Temps stayed below 60c under normal use and seemed stable Last night running idle with Torrent program, CP started restarting in a fuc[b][/b]Kedup way. It wouldnt turn on the first 5 times and the 6th time it turned on @ 2.8 I reset everything to Failsafe defaults and it restared again browsing the web. I set ram at 2.1v (from 1.8v with is below specs) and I typed this. Any ideas??? I'm thinking either Motherboard or PSU.
BUMP
Im feeling left out
Turns out the Motherboard and PSU died... Thanks for the input fellas
You are about to answer a thread that has been inactive for more than 6 months.If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread.
