I got ZALMAN 9700 LED 110mm 2 Ball CPU Cooler
http://www.newegg.com/product/product.asp?item=N82E16835118019
and it has a manual switch (knob) on the outside of PC case to regulate speed, you plug the fan into it, than it into the Mobo - when I have that plugged in - fan does not turn at all (blue led does not come on)...!?
When I disconnect that piece, and plug direct into Mobo - it works, like I said my E4300 (not OCed yet, will be shooting for 3Ghz),so at stock speed at 32 C (which I think it's good?). Also the Sensors View reports (and BIOS I think), fan speed at 800 RPM - can that be right??? It is REALLY quiet too (which is good), just wondering if I got a bad part and am running at lowest speed all the time?
Last, the fan (and the manual speed control knob) both have 3 PIN for power connector, my GIGABYTE GA-965P-S3 LGA 775 Intel P965 Express
http://www.newegg.com/product/product.asp?item=N82E16813128017
has 4 - but it plugs in usign the 3 fine...
Am I doing everything OK here?
Thanks!!!
Thanks!!!
