Tom's Hardware > Forum > Graphic & Displays > TV/Video Cards > Problem with watching 720p HD. Please help!
Forum Graphic & Displays : TV/Video Cards - Problem with watching 720p HD. Please help!
I was watching movie trailers on apple.com on my girlfiriends DEll 9200 laptop or something. We were able to watch the HD trailers on 720p and they ran perfectly.
Then, when I tried to watch them on my computer which I built the 720p definitely looked slow. The framerate seemed to be hurting whereas on that 9200 it was fine. I can't imagine that her Dell outperformed my desktop. I have more RAM and probably a better video card.
I am very lost when it comes to HD on a computer. Can someone tell me based on my specs below what may be the problem?
If this is the wrong forum I would gladly repost it somewhere else.
Sponsored Links
what program are you using to watch the movies with.
Reply to strangestranger
- 0 +
Quicktime. Watching them off the apple.com/trailers website.
Reply to cutter
have you got the latest version, can you use hardware acceleration with quicktime?
Considering I watch HD Movie previews with my Xbox (720 or 1080... and modded). you should have no problem as long as your running a vid card purchased within the last few years.
720 lines of resolution inst that big of a deal for a standard monitor, so you may be running into problems with QT. Have you 1.) Downloaded the movie, 2.) reinstalled QT, or 3.) Played QT files in another player, such as VLC.
Reply to CompTIA_Rep
- 0 +
I thought I did have the latest quicktime updates. I'm not sure what hardware acceleration is.
Reply to cutter
i have had a brainwave or at least by my standards.
pop over to microsofts site and download there trailers. they to have HD movies in 720P as well as 1080i and p i believe. if you can run them fine that migh help diagnose whats wrong.
all i mean by hardware acceleration is by the gfx card helping decode the movie. they are better than a cpu at it AFAIK.
I watch 720/1080i video on a:
XBOX
700mhz
GeForce 3
64megs ram
Your videocard/processor should be able to display those resolutions as I said before, they are not much in the computer monitor world.
720p = 720x480(?) CRTs of the 1980's could do 1600x1200 lines of resoltion.
Current monitors can do 1600x1200 without a problem, and so can the video cards (I am not talking about rendering games at that resolution).
- 0 +
We're talking about decoding 24fps of compressed video at 1280x720 here, not driving a monitor...
So, I have something similar, an Athlon XP 3000+ with 1GB of DDR-400. It can play back H.264 (with CoreAVC or Powerlink's H.264 codec) and Divx at 1280x720 without any problems. It can NOT play back the Apple trailers in Quicktime, though.
Your problem actually is the CPU, as I have the same problem.
If I looked it up correctly, a Dell 9200 has a Pentium M @ 2.1GHz. This is the same clock speed as my CPU, but a Pentium M is more efficient. I wouldn't be surprised if it's enough of a difference to make Quicktime's 720p playback watchable/perfect. My CPU can barely play it back, it's choppy.
Like I said though, that's Quicktime. H.264 and Divx are fine at that resolution.
Reply to joex444
My CPU is a 700mhz (xbox) and it plays just fine. I have a e6600 desktop and it has a hard time playing anything QT (audio or otherwise).
and I know we are not talking about driving monitor resolutions, I am just stating that as an example.
and again:
700MHZ plays 720/1080 video (720 from quicktime) just... bloody... perfect.
exactly how do you play that from an xbox?
i mean, what media do you play it from and also what connection do they use to the t.v, HDtv?
- 0 +
Stranger,
which trailers are you referring to on microsoft. Where can I download comparable 720p ones?
Reply to cutter
Quote :
VIA XBMC
(Xbox Media Center soft mod. I use RGB component.
There are 1066 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vishnuvamp won the Freshman badge
  • 01:00 whiz won the Freshman badge
  • 01:00 jconline won the Uniformed badge
  • 01:00 qiaoda won the Uniformed badge
  • 01:00 sykohedd won the Uniformed badge
  • 01:00 jundja won the Uniformed badge
  • 01:00 cnsftci won the Uniformed badge
  • 01:00 VistaVendetta won the Uniformed badge
  • 01:00 batuchka won the Uniformed badge
  • 01:00 Nick_C won the Uniformed badge
