Memory or Motherboard Problem
Sometimes when I bootup, my memory test doesn't start/finish, it just kinds hangs. Then I reset and it runs fine. However, sometimes my machine just stalls and I get no output to the screen... other times, i get IRQL_NOT_LESS_OR_EQUAL blue screen.
I tested my memory using windows memory test and MemTest86 and it passed the test. Is this a motherboard problem or Memory problem or a voltage problem?
I thought it was the motherboard, so I had it replaced with the same model, but I still have the same error.
The mobo is an ECS P965T-A with the latest BIOS I could find on the website. The RAM is 2GB of OCZ Dual Channel 800MHz non-ECC Gold Edition.
Any suggestions would be greatly appreciated!!!
Thanks!
I've reseated everything a couple times and even moved around the two DIMMs between the 4 slots, but no luck :)
How would I know if it was a PSU problem? I'm using the factory default CMOS settings from ECS.
After restart it does run fine, but maybe a couple reboots later, the same error occurs, if I haven't had the IRQL_NOT_LESS_OR_EQUAL error...
Anything else I should try? I'll try anything!
Ask the community
