Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Last hour check for build before I buy parts
Forum Homebuilt Systems : General Homebuilt - Last hour check for build before I buy parts
Sponsored Links
Looks good overall. The DVD-RW you picked is not capable of writing dual layer, for a few bucks more you should get DL, you may need it soon enough.
Reply to cutthroat
Nice choices, but is there a specific reason for getting XP home?
Reply to Tomster831
Yah I would go for vista even thou i still does'nt support alot of components out there.
Quote :
Reply to col-p-todd
Quote :
It has free upgrade to vista till 3/15 so I can just get the upgrade and wait for 6 months till it supposts my sound and video card drivers.
Reply to chailvr
Quote :
Your system needs about 34A or better on the combined +12v rails. Check the bottom link in my sige for a list of good quality PSUs. The total +12v amps are listed in red.
Thanks!. Should I get a dual or single rail though..some experienced users have reccomended a single rail for direct power to the components. If I dont need one then I think I'll go with the :
http://secure.newegg.com/NewVersio [...] 6817341002
from your list.
Reply to chailvr
There are 1229 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
