Hello. About a month ago, I decided to get a new graphics card along with a new PSU. I got a 500W Coolmax and a 7600GT. I got the PSU First and installed it. It ran fine. Then I got my new graphics card and installed it. They ran fine for about 18 days. Then my PC crashed. I figured it was my PSU that was faulty since it would start but not when my new graphics card was installed. So I sent it back and got a replacement. Hooked it up and same thing, will start but not when the new graphics card is attached. So I figured the problem must stem from my graphics card. Has anyone encountered this? Could some damage might have incurred while I was installing it and that's why it broke. I'm currently getting it exchanged but I'm open to ideas. Thanks for the help.
Nope, didn't overclock or anything. The only game I played was Company of Heroes. Was it possible that I damaged it when installing (Maybe static) and it finally died after 18 days?
It's possible that you damaged it, but it's unlikely - static damage doesn't usually take 18 days to show up - it'd either be completely broken or it'd be completely fine immediately.
If you take the card out and look at it / have a smell of it. Can you see any burnt components? Is there any burning smell? Does the heatsink assembly touch the graphics core? (make sure you earth yourself before taking the card out, of course!)
