Fans not working in Thermaltake Armor case
Just built a new pc and 4 out of the 5 case fans aren't working. The case comes with two 12cm, two 9cm, and one 25cm fan. Only one 12cm fan is working. They all have the 4-ping ide connectors. Is there a certain way I need to connect the fans to the power supply? Thanks in advance.
Intel Core 2 Duo E6600
ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler
EVGA NVIDIA nForce 680i SLI ATX Intel Motherboard
Maxtor HDD 250GB 7200RPM 16MB
OCZ 2GB (2 x 1GB) Gold XTC Edition DDR2 800 (PC2 6400) Memory
EVGA GeForce 8800GTX 768MBFSP Group (Fortron Source) FX700-GLN ATX12V/ EPS12V 700W Quad. SLi Power Supply
Thermaltake Armor Series VA8003BWS Black Full Tower Case w/ 25CM Fan
Arctic Silver 5 Thermal Compound
Gateway 22" WS LCD w/ DVI
Windows XP SP2
2 answers Last reply
More about fans working thermaltake armor case
  1. Are you sure that they are daisy-chained correctly into a power circuit or multiple circuits? I would start there...
  2. I have the same case as you and the 250mm side fan panel. My is also connected to a 4-pin Molex and runs fine. Check your connection again and also use different molex from the power supply.
Power Supplies Cases Components
