Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > Building a Liquid Cooling System
Forum Overclocking : Cooler and Heatsinks - Building a Liquid Cooling System
I was looking into getting a liquid cooling system for my upcoming new computer. Here is the wishlist:
http://secure.newegg.com/NewVersio [...] er=5051427
I was wondering, what exactly do I need to get to build one? Could someone build one for me?
Thanks in advance.
Sponsored Links
Well, you'll need these.
CPU waterblock
GPU block (If you're planning on it)
Northbridge block (you really don't need it, it is a novelty at best. Just get a good Air Cooler if your's is passive or loud)
Pump (Either Danger Den or Swiftecs $75ish pump. They are the same)
Resivoir (or T-line, take your pick)
Tubing (I'd recommend Tygon, 1/2 inch)
Radiator (If only CPU block, 1 or 2 fan rad. CPU+GPU: 2fan, and a 1 fan)
Coolant (save yourself some money, and just get an additive that you mix into distilled water. If you don't get an all in one kind, you will need a Corrosion inhibitor, Algae inhibitor, and also something to absorb more heat.)
Clamps (You can pick up some "worm drive" tube clamps at your local hardware store.)
Swiftec, and Danger Den are both great brands.
You can find most, if not all of this at:
www.petrastech.com
www.crazypc.com
(both respectable sellers).
Your loop should go: Pump-->CPU-->Rad(1)-->(GPU if you want it)-->(IF you got a GPU block) Rad(2))-->Resivoir(or T-line)-->back to pump.
Reply to mcain591
Definatly.
Also, try going to www.xtremesystems.com, and go to watercooling
Reply to mcain591
Here is one more place to buy water cooling components. I ordered 5 times without any problems what so ever.
http://www.sidewindercomputers.com/
Reply to sarsoft
Thanks for all the help, guys...
But my question is, is it worth it? Right now I'm using a Scythe Infinity CPU Cooler, and its working pretty good, being that it's cooling a P4 at the moment. But my fans are LOUD. My case (Thermaltake Shark) supports Liquid Cooling, so I thought I may put it to use, lol. Only problem is that the holes in the back are 3/8, i think, but nothing a drill can't handle. :P
Also, don't you have to replace the coolant every month or so?
Also², would be a bad idea to move a computer with a liquid cooling system in it? Would it like leak water everywhere? 8O
Reply to darkspreader
Aghh, that rumor that you "need to replace your coolant every month" plauge's new water cooling users. The answer is no.
Since you will be able to see the coolant in the tubes, you just need to replace it if you see algae, or of the become extremely foggy.
Head here: Part 2 of the Introduction to Watercooling: Pre-Installation Procedures
(To that title in the thread.)
Following those directions, you shouldn't need to replace coolant for at least a year or 2.
As far as the leak issue, make sure that you tighten your clamps. If you are a lanparty regular, I would recommend getting all metal fittings, and using a "worm drive" clamp.
Why? If you overtighten a worm drive clamp onto a plastic fitting, you will crush it, resulting in leaks galore.
If you have any other questions, feel free to pm me.
Reply to mcain591
There are 1262 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
