Trying to upgrade my system with advice from tomshardware reviews
I'm wondering if these parts fit together
It's mostly the RAM I'm worried about since the motherboard says DDR2 SD and the RAM I found only says DDR2. Does it still fit?
Thanks!
RAM
V-DATA - RAM- 1 GB - DIMM 240-pin - DDR II - 800 MHz / PC2-6400 - CL5 - 1.8 V
CPU
Intel Core 2 Duo E6600, BOX, LGA775
GFX
BFG GeForce 8800GTS, 320MB, PCI-E
MOTHERBOARD
MSI 975X-Platinum/PUP, 975X, LGA775
Thanks!
RAM
CPU
GFX
MOTHERBOARD
