Tom's Hardware > Forum > Home Theatre > HDTV > Toshiba 43H70 Clicks Off, Power Light Blinks
Forum Home Theatre : HDTV - Toshiba 43H70 Clicks Off, Power Light Blinks
Archived from groups: alt.tv.tech.hdtv (More info?)
I have a Toshiba 43H70 (bought new in December 2000) rear projection 43"
HDTV unit that all the sudden does not turn on properly and displays no
picture.
SYMPTOMS:
1) Press power button "on"
2) Red power light comes on steady and you hear TV make the sound as if it
is warming up
3) After only about 1 to 2 seconds, you hear 3 clicks...the same sequence
you would normally hear upon turning it off (when it was working correctly)
4) After 3 or 4 more seconds you hear the built-in speakers click (on or
off, I can't tell)
5) Red power light then stays on steady, but after about 15 seconds it
starts to blink on and off slowly (approximately 2 seconds on and then 2
seconds off) until you unplug it. No sounds are heard upon unplugging it.
At no point is anything seen on the screen. Also, I have unplugged it
altogether for various lengths of time (48+ hours even) in hopes of
resetting a protector, with no luck (used to have to do this if the TV was
ever turned back on immediately after having been turned off; unplugging for
10-15 minutes would reset it).
QUESTIONS:
1) What is wrong with this TV?
2) What sort of part or parts need repair?
3) Is this something I can fix myself (I am skilled in computer repair, but
have never worked inside a TV)?
3) How much should a repair cost for both parts and labor (low and high end
of a price range). An authorized Toshiba repair center quoted me an average
repair cost of $630.
4) Would the replacement part(s) last any longer than the 3.5 years I got on
the original(s)?
5) If this were your TV, would you spend the money to repair?
6) If "no" on Question #4, how can I dispose of the thing in an
environmentally safe way? Does any group take donations of such broken
items?
Thanks for any advice you can pass on, large or small. :^)
-Jason
Sponsored Links
"Jason in Decatur, GA" <sophos@NoSpAm_sophosoft.com> wrote in message
news:qvudnQYuYrJPbWLdRVn-uQ@speakeasy.net...
> picture.
> SYMPTOMS:
> is warming up
correctly)
> off, I can't tell)
was
for
> QUESTIONS:
but
end
average
on
> the original(s)?
> items?
The TV is going into shutdown mode. There are lots of things that can cause
that. Toshiba has a troubleshooting
checklist to help servicecenters. There are some shortcuts but if you hear
HV come up before shutdown the most common
problem is a shorted Convergance amp or audio IC followed by vert out IC.
Repair cost in my shop for average shutdown problems is about $250 and I'm a
Toshiba service center. Toshiba is pretty easy to repair and parts cost are
very low for most problems.
Reply to Anonymous
"Jeff Rigby" <jeffg212@comcast.net> wrote in message
news:zpWdnRcFnPIwmZ3cRVn-pw@comcast.com...
> > picture.
> > SYMPTOMS:
it
> > is warming up
sequence
> correctly)
> > off, I can't tell)
it.
> was
> for
> > QUESTIONS:
> but
> end
> average
got
> on
> > the original(s)?
> > items?
cause
hear
a
are
Just did one of these with a bad op-amp in the digital convergence unit
causing convergence output IC to fail and fuses to blow on its supply. Be
sure to deal with someone who knows the Toshibas. They are pretty easy to
fix, as Jeff said, but lots of less experienced shops will chase their tail
on them and just replace modules rather than solving the problem at the
component level.
Leonard
Reply to Anonymous
Jeff and Leonard,
Cool...you two were right on the money on the ICs being the problem.
I had HH Gregg repair come out to replace the unit's 2 ICs ($236 total:
housecall, parts and labor) and 24 hours later it's still looking good.
I just hope I can get 2 more years out of this TV and I'll be happy.
Thanks again!
-Jason
"Leonard G. Caillouet" <lcaillo_ns_@devoynet.com> wrote in message
news:JGVLc.6273$%S4.3575@bignews1.bellsouth.net...
>> > 43"
>> > picture.
>> > SYMPTOMS:
> it
>> > is warming up
> sequence
>> correctly)
>> > or
>> > off, I can't tell)
>> > 2
> it.
>> was
>> > unplugging
>> for
>> > QUESTIONS:
>> but
>> end
>> average
> got
>> on
>> > the original(s)?
>> > items?
> cause
> hear
>> I'm
> a
> are
> tail
> component level.
> Leonard
Reply to Anonymous
Very common problem with many RPTV designs is the convergnece output devices
failing. Sounds like you got a fair deal from Greggs on the repair cost. BTW
MCM had a bad shipment recently of the STK392-110 devices, they tend to fail
witin two to three weeks and sometimes cause pehripheral damages. MCM did
issue a recall on the devices but do not pay for reservice costs.
"Jason P." <sophos@NoSpAm_sophosoft.com> wrote in message
news:Gc6dnfFDgZH8QL7cRVn-oQ@speakeasy.net...
> Jeff and Leonard,
> Thanks again!
> -Jason
> >> > 43"
no
> >> > picture.
> >> > SYMPTOMS:
if
> > it
> >> > is warming up
> > sequence
> >> correctly)
> >> > or
> >> > off, I can't tell)
it
then
> >> > 2
unplugging
> > it.
it
TV
> >> was
> >> > unplugging
> >> for
> >> > QUESTIONS:
repair,
> >> but
high
> >> end
> >> average
> > got
> >> on
> >> > the original(s)?
broken
> >> > items?
> > cause
> > hear
IC.
> >> I'm
> > a
cost
> > are
Be
to
> > tail
> > component level.
> > Leonard
Reply to Anonymous
You are quite welcome, Jason. The rate is within a few $ of what we charge.
Leonard
> Jeff and Leonard,
> Thanks again!
> -Jason
> >> > 43"
no
> >> > picture.
> >> > SYMPTOMS:
if
> > it
> >> > is warming up
> > sequence
> >> correctly)
> >> > or
> >> > off, I can't tell)
it
then
> >> > 2
unplugging
> > it.
it
TV
> >> was
> >> > unplugging
> >> for
> >> > QUESTIONS:
repair,
> >> but
high
> >> end
> >> average
> > got
> >> on
> >> > the original(s)?
broken
> >> > items?
> > cause
> > hear
IC.
> >> I'm
> > a
cost
> > are
Be
to
> > tail
> > component level.
> > Leonard
Reply to Anonymous
There are 793 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 demondrumer won the Freshman badge
  • 01:00 tehue won the Freshman badge
  • 12:11 mi1ez won the Watchman badge
  • 01:00 sighQ2 won the Freshman badge
  • 09:06 ulysses35 won the CPUs badge
  • 01:00 fleeb won the Freshman badge
  • 01:00 jaymoney61 won the Freshman badge
  • 07:06 amdfangirl won the Watchman badge
  • 01:00 benw won the Freshman badge
  • 01:00 anmjoven won the Freshman badge
