I want to hook up the front panel audio on a Centurion 5 to an Intel DG965RY. The audio cable on the case has a 10 pin connector labled HD audio, a 10 pin connector labled AC97, and a bunch of loose cables with two white paper tags labled AC97 and Azalia. The mobo has two areas labeled Audio. A yellow 9 pin FP Audio and a black 15 pin HD Audio. How do I proceed?
Also there is a case speaker cable, but I dont see a specific speaker connection on the mobo.
I appreciate your help!
