Hi,
First post in this forum, could not think of a better place to turn.
Im designing my new computer, this will be the 4th I will build
on my own, here is the parts and the questions:
Its basicly the same system a friend of mine bought last week,
but this is about 2/3 of the price and doubble on ram ^^
thx for any help I can get!
//Wowbagger
BOX:
Antec 900
great box, no questions
POWER:
ACE RAW DEAL 520W
cheap and lots of power, any comments helpful
VGA:
8800GTS 640mb
seems to be matching the GTX card pritty good
CPU:
AMD ATHLON 64 X2 5200+
good money value, does it have 2 cores?
Memory:
not decided, Im going for 4gigs of ram but not sure what kind?
is it better to only go for 2gigs of really good ram or 4gigs of
cheap? and is heat sinks on ram really nessersary?
Im thinking in the lines of ddr2 PC6400 anyway, comments?
Motherboard:
tricky part number two. All new AM2 motherboards have only
one IDE channel, and i would like to have two so i can re use
my harddrives (until i can affored a new good sata drive).
and the seccond question on this is, what chipset is the best?
Optical:
I will re use my optical drives from my old computer.
Other:
This will be 50/50 gaming and workstation, like 3d rendering and
shit, I will run it on vista buissness, since i got a free copy of that.
//Wowbagger
