So im building a new computer and trying to decide on a good case for my rig, the components i've selected up to this point are:
2x 8800 GTX
eVGA 680i Mobo
C2D 6600
The power supply im up in the air about, it obviously will have to be a fairly large one, but I don't know the exact wattage ill need it to supply.
The two cases im currently looking at are:
Lian-Li v1200B Plus II
COOLER MASTER Stacker RC-832
The differences that I can tell aside from looks would be...
Stacker is SLI Certified (Does that even matter for a case?)
Lian Li has great air flow
Lian Li may have trouble fitting a PSU if it's large.
I'm leaning towards the stacker cause of the certification, but at the same time I really like the Lian Li. Wich should I get, and/or is there a better case I should be looking at?
2x 8800 GTX
eVGA 680i Mobo
C2D 6600
