I know there are alot of these posted on this forum, and I'm afraid that I'm just one more in the masses that would like some techie god to swoop down and tell them if their PC is allright. With that said I feel that my e6600 is runnign a bit warm for no reason. My specs are:
Antec 180p - Case
Intel Core 2 Duo - E6600
Radeon X800 Pro
Intel 965LT - Motherboard
Coolermaster RR-LCH-P9E1 92mm CPU - Fan
No extra case fans outside the standard 3-speed ones that come with the case. The fans are running on low speed.
I ran both TAT, and CoreTemp and both said each core was running around 62 - 67 degrees C no simulated load on the processors. This seemed a bit warm, but that was just me. Any suggestions?
Antec 180p - Case
Radeon X800 Pro
