Did u create a RESTORE point?
DID u create a Password RESET disk?
DID u setup a UPS?
DID u setup and configure a/v and firewalls?
DID u update at WINDOWS update?
goto www.cnet.com and d/l and install ccleaner
goto www.webroot.com and get spysweeper
goto www.lavasoft.com and get ad aware se personal
tons of stuff to do to secure ur pc after a new build.
Get a CD folder or large ziplok bag and place all ur cd's inside with manuals and prod id numbers.
Huh?
Let's take this one step at a time... A RESTORE point will be created when the install is done. That is restore point 0.
Password reset disk??? WTF? Do you set passwords for all of your 20 years' worth of customers, prior to them even getting their systems? If so, I'll not buy from you, thank you.
A UPS? WTF? I think that this is a seperate device, but if there is one built into vista, please enlighten me.
Firewall and AV...
Vista automatically starts a FW. As to AV, that's a personal preference, and judging by your capabilities I would rather trust my own judgement.
Windows update... If you are connected to the internet, and if vista validates I'd assume you are, then like it or not you WILL get the updates.
As to the rest of your post, there are much better tools out there. If the OP needs access to some, he is free to PM me, or ask for others opinions as well. But what you have recommended for the most part is garbage.
Noob.
Byebye, YOU are the weakest link...
