Closed
My eject USB devices icon has disappeared from my System Tray -- How do I get it
Last response: in Windows 7
If you make sure that nothing is accessing your USB device. Windows open, music playing off the device, sending data back and forth, etc... You can unplug it without doing any kind of damage.
Related ressources
Hi there,
I agree with Hawkeye, check to make sure it's just not hidden beside the left pointing or up pointing arrow in the system tray.
Also, remember that you have to have a removable device connected for it to show up. It's not needed if you don't have anything to 'remove safely'
Windows 7 Authority
Also, most usb flash drives are marked optimize for quick removal so there is no need to safely remove device as long as you aren't reading/writing to it at the time of removal.
leefrance said:
Hello, my "eject USB devices icon"
has "disappeared" from my Systems Tray--- How do I get it back. I am using a PC. Thankyou for your valuable time
Create a new shortcut on your desktop as follows:
%windir%\system32\RunDll32.exe shell32.dll,Control_RunDLL hotplug.dll
Name:
Safely Remove USB Device
Change Icon:
Look for Icons here:
C:\WINDOWS\system32\shell32.dll
About 4 clicks to the right is an icon with Green Upward Left Arrow (3rd row of icons) that I use and it
I use this when the system tray icon doesn't show up, also this has a bit more information about what is being ejected.
Jeff
For USB hard drives, the default is also quick removal.
Suggestion:
For USB hard disks, the user may want to enable write caching to improve perfornace. This setting also requires safe removal
Use the device manager Disk drives, while the drive is plugged in, and then properties, then click the policies tab.
If the drive is optiimized for quick removal no problem, but if it's optimized for performance safe removal is important.
Jeff
Ask the community
