Archived from groups: microsoft.public.win2000.security (
More info?)
OK. You probably can do that by configuring NAT and then disabling packet
filtering on the external network adapter that is usually configured
automatically when you configure VPN via Remote Access Management Console.
Open it and go to IP routing/general, find your network adapter, check
properties inbound and outbound filters. You can remove those entries so
that it is configured to receive/send all packets except those listed below.
The link below may also be helpful. -- Steve
http://support.microsoft.com/default.aspx?scid=kb;en-us;299801
"Dev" <somudrodev@hotmail.com> wrote in message
news:1103950826.083565.49100@c13g2000cwb.googlegroups.com...
> What I want is to provide VPN and NAT service in a same windows 2k
> server box.
> Any one has any information about that.
> Steven L Umbach wrote:
>> I am not sure exactly what you mean but if you want them to be able
> to
>> access the internet through the VPN connection configure their VPN
>> connectoid to use the default gateway of your network when connected
> via
>> VPN. Look under properties/networking/tcp ip/properties/advanced -
> use
>> default gateway on remote network. If still having problems use the
> ping and
>> tracert utilities using IP address and name of remote destination to
> check
>> for availability and to find the bottleneck [tracert]. --- Steve
>> news:1103907976.030217.327020@z14g2000cwz.googlegroups.com...
>> > Yes, I mean Internet.
>> > My vpn is configured using RRAS wizard. Yes, I am using RRAS. I
> just
>> > want to provide access to my internal users. Not inbound access. I
> have
>> > alrady install NAT there. But it is not working.
>> > Is it possible to configure NAT and vpn in a same box running win2k
>> > server?
>> > ~/Dev
>> > Bob McCoy [MSFT] wrote:
>> >> First of all, what do you mean by "External LAN"? Are you
> referring
>> > to the
>> >> Internet?
>> >> How is your VPN configured? Are you using RRAS? Are you assuming
>> > that this
>> >> provides access out as well as access in? Has this ever worked
> for
>> > you in
>> >> the past?
>> >> Bob McCoy
>> >> * This posting is provided "AS IS" with no warranties, and confers
> no
>> >> rights.
>> >> * Please note I cannot respond to email questions. Please use
> these
>> >> newsgroups.
>> >> news:1103812325.898654.204470@c13g2000cwb.googlegroups.com...
>> >> > Hi all,
>> >> > I have a win2k server configured as pptp vpn.
>> >> > Everything is working fine. But the users behind the vpn server
>> > cannot
>> >> > access the external LAN. I wan to provide then access to the
>> > external
>> >> > LAN.
>> >> > Here is what I want to do.
>> >> > user ---->vpn server----->external LAN.
>> >> > I need help for this.
>> >> > Mamun
