Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > Help: WLNB-AN-DP101 Airborne™ Embedded Wireless Module
Forum Wireless Networking : Wireless General Discussions - Help: WLNB-AN-DP101 Airborne™ Embedded Wireless Module
Hi,
I tried to connect the WLNB-AN-DP101 to a computer using serial port to communicate using hyperterm for the CLI.
However, port F0 (POST) keeps blinking. Is it normal for it to blink??
I bought a breakout board from http://www.sparkfun.com/commerce/p [...] ts_id=699# to connect to the hirose connector.
I applied 3.3V to DVdd and grounded the GND pins. I also connect F1 and F7 to pins 3 and 2 of RS232 respectively.
Next i run hyperterm. I selected com1, 9600 bits per second, 8 data bits, no parity, 1 stop bit, and hardware flow control.
Is there anything that i have missed out on my connections that causes the blinking??
Thank you in advance.
Sponsored Links
There are 781 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
