I had this in the software help area, but personally I think it is more of a hardware issue, i just can't put my finger on it... Here below is what was in the other forum.
I just recently built a new Intel based system, and everything has been working fine except for one thing, for some reason, when I go to search through folders in any program, the program locks up and freezes. I thought that it was the hard drive going bad, with bad sectors. (I had been having issues with the Hard Drive in question from my last computer.) I just reinstalled windows as well. I have only had this system going for a few hours with the new hard drive, but before on the old hard drive, I was getting "Win32 Generic Process" errors, which effectively stopped any sound on any program that I would open up after that. So my question is, why can't I browse through my hard drive in programs? Is it a software problem (I have been using the same Windows install the entire time,) or is it a hardware problem? Here are my hardware specs.
Processor: Intel e6300 @ 1.86 ghz
Motherboard: Gigabyte GA-965P-DS3 (Rev 2.0)
Video Card: BFG 7600 GT
RAM: Corsair XMS2 DDR2-800 (1 GB)
HD: WD 250 GB SATA
I did have my computer overclocked before, up to 3.0 Ghz, but i only upped the voltages on the FSB and the RAM by .1 and the processor was running 1.375 instead of the default 1.325. Could that have any effect? I haven't ran any memory tests or anything, so if you can help or could point me in a direction, that would be greatly appriecated.
HD: WD 250 GB SATA
