Latest Reviews & Articles
Life At 2 GT/s: 6 GB DDR3-2000 Memory Kits Compared
Memory vendors put a lot of effort into drumming up excitement over high-end memory kits, but many of those products turn out to be vaporware. We test six DDR3-2000 kits that enthusiasts can actually buy today, and push them as far as they'll go. Read more
DDR3 Memory Scaling On AMD's Phenom II X4
DDR3 memory is available in speeds ranging from DDR3-800 to DDR3-2133. Which is the best memory choice for AMD’s Phenom II X4? We tested as many speeds as possible using aggressive and conservative timings to find the sweet spot for your next build. Read more
Intel Core i7-975 Extreme And i7-950 Reviewed
Today Intel launches two high-end processors that take the place of its i7-965 and i7-940 CPUs. More speed? Same price points? We’ll take it! But are the new chips compelling enough to warrant spending more than you would on an i7-920? Read more
AMD Athlon II X2 / Phenom II X2 And Low-Power CPU Bonanza
Eager to let you know it’s been busy, AMD is launching four new processors today: the first Athlon II, a dual-core Phenom II, and two low-power 65W Phenom IIs. We bought ourselves a new Pentium E6300 and let loose with AMD’s latest. Read more
All the Reviews & Articles
Tom's Hardware > Forum > Home Theatre > HDTV > Mitsubishi VS60803 geometry problems
Archived from groups: alt.tv.tech.hdtv (More info?)
I know about two service menus for the Mitsu I have - menu + 2357 and menu +
2359.
I am having problems finding out about some of the advanced functions though.
My TV's geometry is off - the bottom edge is "curved" - so anything like a
banner is like a faint smile - higher at the edges and lower in the middle.
Not a straight line. Avia really shows the problems well.
I also have an appearance of "curving away" on the left and right vertical
edges. As if you took a sheet of paper and wrapped it against the curve of a
baseball bat or something - so it almost appears as if the TV is a scroll
opened up with the ends curving slightly away at the very edges.
I've gone into the menus, but haven't been able to determine what options I
can try to modify. Anything I've tried really didn't make a difference and I
cancelled out so I wouldn't screw it up more.
Is there any type of "restore geometry to default" option? Or does someone
have a source they can point me to on the web or something that lists
descriptoins of the various settings in the advanced service menus on the
Mitsubishi TV's?
Thanks for any suggestions.
john
John
Sponsored Links
"john" <john@john.com> wrote in message
news:YCWOc.20808479$Id.3445678@news.easynews.com...
> 2359.
though.
middle.
a
I
I
> Mitsubishi TV's?
> john
John, the degree of precision that you are trying to achieve is likely to
require a tech who is intimately familiar with convergence, with the
Mitsubishi menus, and with the interactions between adjustments at the edges
of these sets. Unfortunately, they were sometimes not straightforward
because some adjustments limited the range of others. It would be unlikely
that you could be given the proper instructions without some hands-on
tutoring. Lots of good techs can't get it right. I'd suggest you get a
copy of the manual if you really want to tackle it, but even then you will
likely not be able to sort out the needed adjustments.
Leonard
Reply to Anonymous
There are 841 identified and unidentified users. To see the list of identified users, Click here.
You are about to answer a thread that has been inactive for more than 6 months. If you still wish to proceed, please ensure that your posting is original and does not duplicate or overlap any prior responses to this thread. Add a reply Cancel
Sponsored links
