Hi, I have some questions about calculating maximum power consumption.
I'm looking at an ASUS P5LD2 mb and an Intel P4 641 3.2GHz. The processor's maximum power consumption is around 115W. However, the board's consumption is 350W. But does the 350W include the CPU or just the board itself?
In the mb's manual, it says this about the power consumption:
"Use of an ATX 12 V Specification 2.0 -compliant power supply unit (PSU) that provides a minimum power of 350 W is recommended for a fully-configured system. Use of a PSU with a higher power output is recommended when configuring a system with more power consuming devices. The system may become unstable or may not boot up if the power is inadequate."
So do they already include the CPU in the 350W?
My second question is how much power does memory usually consume?
My third question is do I add the amperes together if the PSU I choose has two +12V rails?
Lastly, how do I figure out the amperes used by each component? I'm guessing that if I have the power, I can divide it by 12V to get the amperes?
I hope I'm on the right track. I'm really new at reading whitepapers and stuff so a lot of it is guesswork. I'd really like some help. Thanks!
