I've built this rig in September, and everything was working fine for a while:
Case: Thermaltake VB6000BWS Swing
MOBO: MSI K9N Platinum
CPU: AMD X2 +3800 AM2 @ 2.10 GHz (just above stock)
GPU: ATI Radeon X800XL, running Catalyst 7.1 drivers
RAM: Corsair XMS 2 TWIN2X1024-5400C4 Matched Pairs(2x512MB) Xtreme Memory DDR2 667Mhz PC5400 240-pin Unbuffered
HDD: 1 Seagate 7200.9 250GB (ST3250620AS), 1 Seagate 7200.10 320 GB (ST3320620AS)
PSU: Enermax NoiseTaker II EG-425P-VE Ver.2.2 SFMA P Series 420 Watt
OS: windows XP Pro SP2
However, a couple months ago I started having an annoying problem. Whenever I start up the system, it gets through the "Starting windows XP" screen with the blue progress bar, and then it immediately reboots.
Once it reboots, it brings up the "Sorry, but Windows did not start properly last time" and gives the typical options, i.e Safe Mode, Command Prompt, Start Windows Normally, etc. I always choose Start Windows Normally, and then everything boots up fine. This happens EVERY time I turn the system on.
I have a feeling its a software problem, and I'm pretty sure it started after I installed the Catalyst 6.11 or 6.12.
While this isn't critical, its become a great annoyance, and clearly should not be happening. My question is, has anyone come across this error? If so, what was the cause? Is there a solution?
Thanks in advance!
Thanks in advance!
