Well for those people that have seen the "mods" to take a PSU and water cool it, I present you Koolances new 1200W Liquid-Cooled PSU.
http://www.koolance.com/shop/product_info.php?products_id=387
Love the idea and the concept. Cost seems to be around $500, which is the same cost of PC Power and Cooling's 1000W system. Though PCP&C have been around and have more "sturdy" PSUs, so I give them credit on that.
Here is a quick run down of the Koolance system:
Type: EPS12V
Max. Power 1200W Continuous, 1400W Peak (@ 40�C)
Operating Range 90-264 VAC, Auto Switching
Current 15A @ 115V
Fan Dual Ball-Bearing 120mm, 30-107CFM, 25-33dBA, Temperature Adjusting
Modular Cabling Yes
PFC Active
Efficiency >80%
Power Factor >0.9
DC Output
+5V @ 30A
+12V @ 96A (12V1@18A, 12V2@18A, 12V3@30A,
12V4@30A); total combined 12V max = 85A
-12V @ 0.8A
+3.3V @ 30A
+5VSB @ 3.0A
Regulation 3% (3.3V, +5V, +12V) +9-5% (-12V)
Ripple 1% (p-p)
Hold Time 16ms min.
PG Delay 100~500ms
OV Protection +3.3V, +5V, +12V
OC Protection +3.3V, +5V, �12V
Temperature 0-40�C
Humidity 20-90% RH
Certifications (pending)
Connectors
1 x 24-pin motherboard
1 x 8-pin 12V CPU/motherboard
4 x (1-plug) PCI-E
2 x (3-plug) SATA
2 x (4-plug) Molex peripheral
1 x (4-plug + 1 FD) Molex peripheral + floppy
For those that are wanting to build a 100% watercooled system, this may be your final step towards that.
Type: EPS12V
Current 15A @ 115V
Modular Cabling Yes
PFC Active
Efficiency >80%
Power Factor >0.9
DC Output
+5V @ 30A
-12V @ 0.8A
+3.3V @ 30A
+5VSB @ 3.0A
Ripple 1% (p-p)
Hold Time 16ms min.
PG Delay 100~500ms
Temperature 0-40�C
Humidity 20-90% RH
Connectors
4 x (1-plug) PCI-E
2 x (3-plug) SATA
